Is there any license available for this (rslinx 3.60)?
RS Linx 3.60
Rawle30
RS Linx 3.60
Hi all,
resrodricba
Re: RS Linx 3.60
C:\Program Files\Rockwell Software\RSLinx\RSLINX.EXE
Address 1A6746
From 0F 85 46 03 00 00
To__ E9 2C 00 00 00 90
C:\Program Files\Rockwell Software\RSLinx\FTAStub.dll
Address 11E2
From 40 03
To__ 09 00
Add the following into License file.
Typically found in:
C:\Documents and Settings\All Users\Documents\Rockwell Automation\Activations
Address 1A6746
Address 11E2
From 40 03
To__ 09 00
Typically found in:
# RSLinx Classic Professional
FEATURE RSLINX.EXE flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLinx Classic Professional" SN=0000000001 \
SIGN="0034 5678 90AB CDEF 1122 3344 5566 7700 FFFF FFFF FFFF \
FFFF FFFF FFFF FFFF"
# RSLinx Classic Gateway
FEATURE RSLINX.GW flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLinx Classic Gateway" SN=0000000001 \
# RSLinx Classic Single-Node
FEATURE RSLINX.SN flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLinx Classic Single-Node" SN=0000000001 \
FFFF FFFF FFFF FFFF"-
shl235
lefada
Re: RS Linx 3.60
Guys,
Sorry for my English i'm french !
I do this method for Rslinx 3.6, but it doesn't work for me
I'm in Grass period
Please Help me
I'm in Grass period
Please Help me
resrodricba
Re: RS Linx 3.60
try this (worked fine for me)
Just run this batch script
(tested on windows XP SP3 and Windows 7 x64)
Code:
cd "C:\Documents and Settings\All Users\Application Data\Rockwell Automation\FactoryTalk Activation\"
attrib -h *.*
del *.* /F/Q
...et voila! Grace period restarts from beginning!
so, if you alredy do the crack procedure, the license will work
Code:
attrib -h *.*
del *.* /F/Q
Moofcba
Re: RS Linx 3.60
I can't activate rslinx like "gateway", always is like "lite". I need Rslinx Gateway.
Anyone can help me with this?..
