I have lost a password of V810 Hakko Monitor. Now i need to read some parametter from V810 Monitor to PC, so anyone have a way for reset it's password?
Reset password for Hakko Monitor V8
redvil
Hi everyone!
redvil
Re: Reset password for Hakko Monitor V8
Can anyone help me?
bahramfattahi
hello
your PlC has ecternal memory ( flash or ram) ?
serega_nf
I had the same problem with V7. Try to "AutoIT" program. You should write the script for sorting password from 0 to 999999.
write this code into script
WinWaitActive('Password')
for $i = 0 to 999999 step 1
ControlSetText('Password','','Edit1',$i)
ControlClick('Password','OK','Button1')
if ControlClick('Password','OK','Button1') = 0 then
MsgBox (1,"",$i)
Else
EndIf
Next
run it and wait. Your window with Password text box had to be active
If script will find password - it will show Message Box with password. But it is one little problem. If your password begins from 0 or 00 or 000 or 0000 - you had to write another code for this script. It is a lot of information about this program in internet, but if you cant write the script by yourself - write here - I will help. Best regards!
MsgBox (1,"",$i)
Else
EndIf
Next
