i use an oldfashioned Software called VisAM 667 which needs a Dongle to run in Pro Mode.
The Dongle seems to be an old Aladdin Hardlock Twin ("FAST"? I'm not sure).
It has gray/turquoise colored plastic and in the window there is the Word "Hardlock" above the serial number.
It looks almost like this Dongle, but on my Dongle there is the word "FAST" at the turquoise colored area on the right-hand side:
http://www.wie-tec.de/images/product_im ... /117_0.jpg
Is there an easy way to emulate this dongle?
Or do you know a way to run VisAM without a dongle?
There seems to be a newer VisAM-Version(9.x). If this version is downwardly compatible to the projects, do you know a way to run it without a dongle?
Thanks a lot,
TheFrozenOne
Hardlock Dongle/VisAM 667
xiaomian1st
Re: Hardlock Dongle/VisAM 667
try to search "HASPHL2007" I use to dump my dongle on windows XP and it works fine for me. it only working on a 32bits system not 64bits, otherwise, you need to buy a licence from the company
