I'm having a old A173UH CPU, where I' having problem when connecting with Gx-Developer or it'motio software SW22.
The same cable & driver is working fine with A2USH CPU-S1 & connecting to GX-Developer without any issue.
I've checked with changing port settings & drivers, but no change. Finally, I've installed new CPU A173UH after reprogramming it with logic & motion programs & servo settings.
After sometimes, the new CPU is also not able to connect to PC.
Is there any option in system memory to restrict the access via serial port? It's showing pop up for listed below any of the following error : communication timeout, cable error, tx speed not supported, monitor condition set status read by device, project & PLC models are different <ES:0180840b>, But I think, cable is ok, since it working with A2USh; Tx speed is fixed & no other option, PLC model is correctly selected, but I don't understand: "monitor condition set status read by device", but. I don't think any issue with it's settings.
I've check both in RUN mode & STOP mode, also with RESET & LATCH CLEAR operation.
Any feedback/suggestions?
posting.php?mode=post&f=3#
Thanks in advance.
A173UH CPU connection problem
Re: A173UH CPU connection problem
can you share software motion control A series, please
