Just want to share what I had problems with.
After installing RSLogix5000 v20 the computer became very slow. If you look in the EventViewer you will see continious errors: "a-b virtual backplane service failed to start". This is because it is looking for the CIP USB (activator USB). If you have a corporate version you need to disable this by removing USBCIPHelper.exe from the start-up.
This can be done by either Start\Run\msconfig\Startup and untick the USBCIPHelper.exe or uninstall USBCIP completely.
alexbeatle
babaych
Re: a-b virtual backplane service failed to start
Your post helpful for me.
TcoSj
Thank you your advice helped me!
