Good day,
I had installed the RSBizWare package. Installed and configured MS SqlExpress 2008. Created the database, and configured the OBDC data connection.
My problem shows when i try to open the configuration console. it prompt for a user name and a password. Also for the server's name and port. Once i enter de login data and press de login button it shows the next message:
"The system cannot log you on. Your FactoryTalk User was not found in the RSBizWare database."
I'm using the same user i use for windows authentification. If i use another user, it pops up a windows telling me it cann't authenticate the user.
I followed all the steps in the manual for configuring the system.
Problem setting up Historian Classic
loztos
Re: Problem setting up Historian Classic
After some tries, i ended opening the FactoryTalk Administration Console and noted there was no users. Then i proceed to create the same user mentioned in the guide (BizWareUser) and another Windows Aunthenticated user (the one i log on into windows). Checked all the permissions for each user.
Once i created both users, opened the Configuration Console and tried to log in again with the user BizWareUser. Now it logged in succesfully =)
P.S. (I haven't used Historian ever before until now)
