Hi
I want to know how to create excel or PDF report by using Vijeo Citect
thanks in advance
[?]: create excel or PDF report by using Vijeo Citect
Re: Vijeo Citect 7.2: Creating Report
1) For PDF report use Device type PRINTER. Use PRINTER drivers types PDFCreaters, for example BULLZIP PDF Printer.
2) For output to excel You do not have to use reports. Use cicode functions and DDE, or ODBC, or ActiveX, or OLEAutomation+CitectVBA, or Device type CSV or ...
Re: [?]: create excel or PDF report by using Vijeo Citect
thanks for reply
i am new to scada system could you explain more?
What do you already know?
Devices?
Call cicode functions?
Use Reports?
Use Trends?
Use HMI?
If you do not have the basic concepts I will not be able to explain.
Devices?
Use Reports?
Use Trends?
Use HMI?
I knew how to create report az *.rtf file and also showing report in citect. is there any reference that i can read and learn?
thanks for your help
1. Download driver for print to PDF: for example http://www.bullzip.com/products/pdf/info.php
2. Install this Driver to system
3. In Citect create Device: type=PrinterDev, name=printerName
