I grabbed the installation file, but need a serial to install! Also is there a DLL or lic available?
EDIT: Figured out the LIC part for setup. Just enter 1835 and then some random numbers. Now need crack for v20.01!
RSLogix 5000 Emulate Serial
scadavn
Re: RSLogix 5000 Emulate Serial
Hi
You can use serial :1835xxxxxx
I have Master key but I dont how to share to you. Because it just is transferred from HDD to HDD
The master key is used for all RASoft <V20 (RSLogic 2K, RSEmu..)
BR
BR
afrz1
I have a masterdisc too but it only goes up to 19.
Where did you download it from? You can move it to a floppy with the license transfer utility. You can use Virtual Floppy Drive to create a drive, assign it a letter and create a writeable image for it (so windows thinks it's a floppy drive with a floppy in it)
Please PM if you can hook up!
