Does anyone knows how to download firmware on PanelView600?
and also where i can get file system for this panel? and any software to use?
thnak you
[?]: Firmware for Panelview
Ryzhij
Re: Firmware for Panelview
For PanelView600 or for PanelViewPlus600 firmware you need?
Let me know Catalog No. your device.
IMHO the best way updating is the use flash card.
It's very simple:
Write file on flash card -> Inset card into panel -> Power On -> Wait -> Enjoy
But any project in panel will be lost!
It's very simple:
hiecham
Re: [?]: Firmware for Panelview
thnkx for reply, PanelView 600 cat: 2711-K6C8 Ser:B
excuse my english
excuse my english
Ryzhij
hiecham
thank you very much.
but when I lit the device (PANELVIEW) LED blinks default continues and the screen does not turn on, is what his means that the device needs an update??
Ryzhij
How old your Panel? Maybe replace back-light lamp to need?
hiecham
about 6 years.
but i don't have backlight lamp for change; it's commercialised??
Ryzhij
Yes, these lamps are sold as spare parts.
But!!!
Unfortunately, I'm faced with the fact that apparently the same panels are inside a display matrix from different vendors, and of course, the different backlight.
Refer to a service center. Maybe there will be something to offer.
But!!!
hiecham
thank you very much
Tecon
hi,
I got question about firmware too,
Had some work to do on this panel:
I'm using Factory Talk View Studio 6.10.00 (CPR 9 SR 4), Patch 00, Build 09
The problem is that I can't change any firmware on factory. So is there any way to tell if I can modify/upload project with this? Or what I have to install to do it. And I got to do it in one visit
Thanks for any suggestions.
varaderorules
hi, its possible to change the internal batery? How i do?
it´s a panelview 600.
tks
tks
