I'm having trouble accessing the card NO8I (8-channel analog output) on a remote machine using an ASB module (1747-ASB).
Could someone give me a hint how would the blocks transfers?
Nor could declare that card and list the I / O configuration.
You should be able to do a generic block read / write transfer. Get the number of configuration words from the card documentation for the BTR and the number of data words for the BTR. Point the btr/btw to the chassis / group. You will need to manually configure the card config words - old school. Let me know if I can help.
