unPassword CodeSys library
другие контроллеры
azhw
[solved] Is Possible to unpassword ABB CoDeSys User Library?
Post by azhw »
I have a ABB AC500 PLC and project files writed with CoDeSys V2.3
when I open the project with CoDeSys, a pop-up windows shows for asking input a password. (wow)
this is the codesys library file
http://depositfiles.com/files/8c9pr0r30
Is there some tools can unpassword the file ?
or somebody who could help me to get the password?
Thanks all . (tyou)
azhw
Re: [help] Is Possible to unpassword ABB CoDeSys User Libra
Post by azhw »
and this is another user library file:
http://depositfiles.com/files/zhwaarg0f
when I opened the project file which reference this library file,
NO pop-up window show for inputing password,
directly shows a error window, the error information is as follow:
The following libraries could not be loaded.
heroctol.lib*2.9.10 14:31:16
. . . . . . . | OK|
who know what's the problem ?
(nuser) Thanks all, again (tyou)
Linkinx64
Post by Linkinx64 »
It is possible to unpassword, but... the popup dialog asking not for a password. It asking for a KEY.
This library was saved as an external encrypted library.
So this is not just "black box". As a result - library can't be added to project without entering that key.
I guess you see the error window because of that.
I need some time to research the encryption/decryption logic OR...
if CoDeSys really prompt for a PASSWORD (not for a KEY) - send me whole project, the library key must be stored somewhere in there...
azhw
Post by azhw »
This is my whole project files, please read "Readme.txt" file.
http://depositfiles.com/files/k4j0kvuq6
Thanks for help from Linkinx64,
Thanks all !
(tyou)
azhw
Re: [?]: Is Possible to unpassword ABB CoDeSys User Library
Post by azhw »
I have totally knew the encrypt algorithm which is used to generate the " CoDeSys Internal Library File (*.lib)"
but... (no)
only from encrypted *.lib file, I could find out only a little information and couldn't decrypt it.
still for help!! (tyou)
Linkinx64
Post by Linkinx64 »
At the moment I can only say the follow information about heroctrol.lib:
1. The library has no password protection inside.
2. User key is greater or equal 5 characters.
I feel on pictures below referring to the same data block:
heroctrol.lib:
not encrypted library:
Check the difference in columns: when data block contains same data (00) after encryption it looks like series where low bits keeps same and high bits changing. E.g., for column #2: C9 F9 E9 99 89. For identical data block you may also see next row is very similar to previous. The data almost repeats each 16 bytes... so, cryptographic key length = 16 bytes.
If it is possible to define repeatability per each row and if there are simple byte operation is used (e.g. key-byte XOR file-byte) - the chance to decrypt file is quite big..
azhw
Post by azhw »
Thanks, Linkinx64!
You are right. It's a KEY, not password.
I have solved this problem and opened my user library files,
Thanks all, again!
tox92
Post by tox92 »
I need help on this CodeSys library. If you explain me how to do, it would be great.
https://rapidshare.com/files/355085887/ModbusTCP.lib
Thanks.
Linkinx64
Re: [?+]: unPassword Library in ABB Compact Control Builder
Post by Linkinx64 »
tox92 wrote:I need help on this CodeSys library. If you explain me how to do, it would be great.
I will explain: type 3SMODTCP when that library request for a password.
amit_sabby wrote:http://dl.dropbox.com/u/36769999/WINDER-1-0-0.rar
i would like to have your service again.
please i need password for few libraries in link given.
thanks for your last posting.
ACS600 and WINDER: matabunkay
WINDER_2: KREMIKOVTZI
Umencho
Re: unPassword CodeSys library
Post by Umencho »
Can you attach ModbusTCP lib again in order to try it?
BR
Linkinx64
Post by Linkinx64 »
Umencho
Post by Umencho »
Password is correct. :lol: 3SMODTCP
tox92
Post by tox92 »
I know it works ! (oo) I just mean how did you do to find it ? (sbutton)
azhw
Post by azhw »
tox92 wrote:I know it works ! (oo) I just mean how did you do to find it ? (sbutton)
your lib file is very simple,
only read password, no write password, no usergroup passwords (level 0-7)
especially no key!
search this forum with keywords "Bechoff keygen"
you can also get the correct password in 1 second!
Umencho
Post by Umencho »
Yes, search it in forum. To mention that 'Bechoff way' is possible do not helps in some cases. (boom) :haha:
BR
Linkinx64
Post by Linkinx64 »
I cannot find any "bechoff soft" in forum search.
Could you place here the link to the "bechoff soft" topic?
Umencho
Post by Umencho »
It should be Beckhoff KeyGen.
BR
Linkinx64
Post by Linkinx64 »
Thanks!
A good tool but not working in some cases when number of passwords in library > 1.
In v2.4 when fail to decrypt "need to pay for help" :haha:
Umencho
Post by Umencho »
Exactly.
In 2.3 and decrypt is not working too.
azhw
Post by azhw »
it always could crack the read/write password,
but for some lib file with two kinds of passwords at same time,
it will fail to crack group passwords.
if you have the problem, please upload the files and I can help
twistermcneal
Post by twistermcneal »
Hello everyone!
can anyone decode this codesys lib?
http://www.file-upload.net/download-738 ... i.Lib.html
Thanks in advance
Chupakabra
Post by Chupakabra »
Can you attach ModbusTCP lib again? !!!
asen
Re: [solved] Is Possible to unpassword ABB CoDeSys User Libr
Post by asen »
Hello Linkinx64,
Could you please help me unpassword in following zip?
[dead] :/3054757019/abc.zip
Thank you.
cnCraneBasicLib
cnCraneStandardLib
cnGrabControlLib
cnGsuAutoLib
cnGsuBasicLib
marcino_p
Post by marcino_p »
Hello
I have library coded with CodeSys.
File: http://s000.tinyupload.com/?file_id=516 ... 6776742830
Unfortunatelly there are two passwords set at the same time.
Can You guys help me?
Martin.
PS. If this will encourage You I will pay for help.
codesysplc81
Post by codesysplc81 »
Hy all.
I have library coded with CodeSys 2.2 with password, and I have a Beckhoff KEY V2.1, which can not be opened.
If you have a version V2.4 or greater, would you send me a link where I can download , please?
Lib: http://www.filedropper.com/showdownload.php/atmobaseqr
Regards .
PS: I have a version 2.4 but does not resolve. If anyone has any idea how to open the library , please write to me
yeosh99
Post by yeosh99 »
Anyone can share "Bechoff keygen"? Cos i cant find it.
Sbiughy
Post by Sbiughy »
yeosh99 wrote:Anyone can share "Bechoff keygen"? Cos i cant find it.
up this post because me too I can't find the tool.
ehab_abdelaleem
Post by ehab_abdelaleem »
Plz I have a project at plc abb ac500 with codesys when I try to open it it ask for password and there are levels for it from 0 to 7 can I know password
Guille
Post by Guille »
You can try with this (maybe it works)
http://www.plcforum.uz.ua/viewtopic.php?t=21290
