I'm working with RSLogix5000 V20 using ControlLogix L71CPU and 1756-EN2T communicate with three Flex I/O using 1794-AENT. In the I/O Configuration, i want to delete flex i/o 1794-IB16 but i've got error message :
"Failed to delete module '[7]1794-IB16/A' Module is not initialized. Likely cause is the module identity (CIP Key) or the module parent is not set"
Please advise
[?]: RS Logix5000 "Failed to delete module"
ciwa
jimmyBee
Re: [?]: RS Logix5000 "Failed to delete module"
I am also having this issue. Does anyone know why?
soundview00
Make sure that you have the proper 'EDS' files installed. If not, then install them.
