[LINK]: Softlogix v20
dimodimo
Post by dimodimo »
Hello everyone,
Can anybody upload Softlogix v20?
Thank you very much for your attention.
guolibin
Re: [Request]: Softlogix v20
Post by guolibin »
hussein kamal
Re: [LINK]: Softlogix v20
Post by hussein kamal »
hi (fback) (fback) (fback)
i want to ask how i activate Softlogix v20 can you help me in that
thanks to you
dimodimo
Post by dimodimo »
Dear guolibin,
Thank you very much for share! (tyou)
hussein kamal look here:
viewtopic.php?f=41&t=15633&start=50#p54538
hussein kamal
Dear dimodimo
thank you for helping me but i try to activated using that's way but not working because that's first time to make that if you have description how make it i will be grateful
(tyou) (tyou)
grayfox
Post by grayfox »
Here it goes
Tested and working
1-On the folder "C:\Program Files\Rockwell Automation\SoftLogix5800"
Look for the fallowing DLL RSSL5K32.dll
Hex edit:
Change 34 02 to 30 90
2-On the folder "C:\Documents and Settings\All Users\Documents\Rockwell Automation\Activations"
Add on the "ftasystem.lic" file the fallowing entry:
FEATURE SftLgx58.60 flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:oftLogix5860" SN=0000000001 \
SIGN="0034 5678 90AB CDEF 1122 3344 5566 7700 FFFF FFFF FFFF \
FFFF FFFF FFFF FFFF"
Good luck (pgood)
Helder
Post by Helder »
hi grayfox,
I can find 34 02!!!!! :o :o :o :o :o
what can i do??? :? :? :? :?
(sos) (sos)
Helder
Post by Helder »
It's working now.... :D :D
Thank you... (tyou) (tyou)
Tanke85
Post by Tanke85 »
Could you explain with more details? Because I already look for "34 02" with HexEdit Pro, but I got a lot of results, wich one should I change to "30 90"? If I change only the first one SoftLogix doesn't execute, if I change every one i get "Activation Error". (no)
Thanks in advance!
caccioz
Post by caccioz »
HI ALL
Sorry all ,but Why not working with me this activation Softlogix V20?
Hex edit:
Change 34 02 to 30 90 FC339
HOSTID=ANY vendor_info="PRODUCT_NAME:SoftLogix5860" SN=0000000001 \
MY RESULTS :
In Factory Talk manager / TAB Manage Activations I see properly license SoftLogix 5860 but NOT WORKING !!
When I run SoftLogix Chassis Monitor a window appears that says : Failed to activate SoftLogix 5800
Why ? Please Help me !!! Thanks
mdim
Post by mdim »
Try to disable rs master license if you have it.
just comment the rows with rsmaster and check
On my PC it worked.
caccioz
Post by caccioz »
(oo) (clap) (gpost)
Great !! Thanks mdim Now work !!
(tyou)
zjjunior
Post by zjjunior »
(gpost)
Amazing, it works like magic!!
Thanks!!
calabazo13
Post by calabazo13 »
Incredible it works perfectly thanks mdim
neto136
Post by neto136 »
(oo)
PERFET, MAN!!!!
All working now!
Thanks a lot!!!
(gpost)
Rawle30
Post by Rawle30 »
I need some assistance, I'm getting the following .....
I do not have any master license to disable....here is what I have.....
Spoiler
# Rockwell Automation License File
# Copyright (C) 2003-2010 All Rights Reserved
SERVER this_host ANY
USE_SERVER
VENDOR flexsvr
INCREMENT fta.system flexsvr 1.00 permanent 1 VENDOR_STRING=1 \
vendor_info="PRODUCT_NAME:FTA System Placeholder" SN=1 \
SIGN="00FB D8C8 C8F8 49F2 480A E303 5567 E100 A110 03FF 3224 \
F038 B859 C955 5900"
FEATURE RS5K_700.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_700.exe" SN=8283999999 \
SIGN="0088 4C88 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RSLINX.EXE flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE" SN=8283999999 \
SIGN="00BF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RSLINX.GW flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE Gateway" SN=8283999999 \
SIGN="00CF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RSLINX.SN flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSLINX.EXE SN" SN=8283999999 \
SIGN="00DF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_GLX.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_GLX.exe" SN=8283999999 \
SIGN="00EF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_MLP.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RS5K_MLP.exe" SN=8283999999 \
SIGN="00FF 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
FEATURE RS5K_000.exe flexsvr 1.0 permanent 10 VENDOR_STRING=8283999999 \
SIGN="009F 8888 9999 CCCC 1122 3344 5566 7700 FFFF FFFF FFFF \
travispang
Post by travispang »
" Failed to activate SoftLogix5800: No activations available "
Why and How ?
peterg70
Post by peterg70 »
Why = You forgot or haven't done some patching required.
How = You need to patch and install the correct license.
sk83
Post by sk83 »
Dear All Expert Member,
Is it possible install Softlogix and RSLogix Emulate at the same time ?
Because I had try to install Softlogix V20 and RSLogix Emulate V20.01 not succes. (wow) (no)
"The windows message pop up show is incompatible "
Juscelio
Post by Juscelio »
Working fine! Thanks!
Tensaiga
Post by Tensaiga »
Hello I tried the same method as well but I am also getting a message that says can't be actived and I do not see a master license in my activations?
Could someone please enlighten me as to where did you find yours?
Thank You!
gohar472
Post by gohar472 »
Hello All,
I need to use softlogix 5800 v20, I have installed but stuck at activation.
I have tried a lot of times with Hex editing RSSL5K32.dll but still unable to get softlogix activated.
It would be a great help for me if anyone can upload patched RSSL5K32.dll file and ftasystem.lic.
quoccuong1195
Post by quoccuong1195 »
mdim wrote:Try to disable rs master license if you have it.
On my PC it worked.
sorry, but how to disable rs master license?
tmdn0017
Post by tmdn0017 »
There is nothing there. It shows "invalid link"
Is there another link where I can download softlogix v20?
Hammer2
Post by Hammer2 »
JPozzo3011
Post by JPozzo3011 »
could you please upload it again ?
mjd-ee
Post by mjd-ee »
vergonio
Post by vergonio »
Vitek54rus
Post by Vitek54rus »
Hellow! Can anuone give crack for SoftLogix v19 or v21? Please!
Alail
Post by Alail »
Can someone update the link to Softlogix
Cristiano14
Post by Cristiano14 »
I'm looking for Factorytalk View Studio Site Edition v9.00.00, does anyone have it? Can someone help me?
Thanks!
bubblegumer
Post by bubblegumer »
Greetings! Can anyone refresh link for downloading? Thanks!
Kh_444
Post by Kh_444 »
Can you refresh the link please?
