[?]: how i can connect Micrologix 1200?
Antwan_jacoup
soundview00
Re: need help . how i can connect this PLC ??????????
Check to see your COM port is correct, if everything is correct, then try a slower Baud Rate. There are other things that you could try, but I'd start there.
PS: Make sure that you have the correct version of RSLinx (matches the micrologix version or greater) and EDS files installed.
Antwan_jacoup
I tried to do this after reading your message, but without results and i use RSlinx 2.57.00.14 CPR 9 SR 3
