i have two plc s7 300 315-2dp(slave/master)
but use one cp 342-5 on the slave plc but not used cp342-5 on the master plc only dp cpu
Length 12-byte block of data to send and how should I use
[?]: Profibus network problem (master/slave)
Re: [?]: Profibas network problem (master/slave)
You useELYAS_GH wrote:i have two plc s7 300 315-2dp(slave/master)
http://support.automation.siemens.com/W ... n/20987807
glhf
