Hi all,
I'm looking for how to activate rsview32 7.60. Please help
[?]: RSView32 7.60 activation
numpoochong
Re: [?]: RSView32 7.60 activation
# Rockwell Software License File
# Copyright (C) 2003 All Rights Reserved
INCREMENT RSVIEW.D32K flexsvr 1.00 permanent uncounted \
VENDOR_STRING=1340017624 HOSTID=001d9246b028 \
vendor_info="PRODUCT_NAME:RSView32 Works 32k" SN=0000000001 \
SIGN="00D8 1580 18CD 138A 8F63 F630 A73C 6A00 B865 77BA 2712 \
D707 A652 DF95 A84B"
Mishgun
Activation RSView32 v.7.60
Hi All,
Could anyone share the method how to activation RSView32 v.7.60?
Thanks.
Thanks.
Mishgun
What wrote numpoochong not working, but (thanks soundview00, look topic: Rockwell FactoryTalk Activation Method) this method works:
Change in hex edit: C:\Program Files\Rockwell Software\RDM\RSCVW32.dll
address FC339: 34 02 -> 30 90
Add in C:\Users\Public\Documents\Rockwell Automation\Activations\ftasystem.lic
FEATURE RSVIEW.D70K flexsvr 1.0 permanent 10 VENDOR_STRING=9999999 \
HOSTID=ANY vendor_info="PRODUCT_NAME:RSVIEW.D70K" SN=0000000001 \
SIGN="0034 5678 90AB CDEF 1122 3344 5566 7700 FFFF FFFF FFFF \
FFFF FFFF FFFF FFFF"
Thanks to all, the topic is closed.
chrisj2012ph
address FC339: 34 02 -> 30 90 ==>> Done
FFFF FFFF FFFF FFFF" ==>> How? Should I add it like this as shown below?
___________________________________________
# Rockwell Automation License File
# Copyright (C) 2003-2010 All Rights Reserved
SERVER this_host ANY
USE_SERVER
VENDOR flexsvr
INCREMENT fta.system flexsvr 1.00 permanent 1 VENDOR_STRING=1 \
vendor_info="PRODUCT_NAME:FTA System Placeholder" SN=1 \
SIGN="00FB D8C8 C8F8 49F2 480A E303 5567 E100 A110 03FF 3224 \
F038 B859 C955 5900"
Not working for me =(. I even tried re-installing RSView32 7.6 using Serial Number = 0000000001, but still did not work.
Any suggestions? What did I do wrong?
USE_SERVER
VENDOR flexsvr
Parveen Sharma
I have RSView21 Runtime 1500 Revision : 7.50.00 but when i activate that with Hex Editor so i have not found FC339 value 34 02. That original value is 20 69 than i was changed the value with 34 02. but i have not success...
Please tell me how can possible that Activate the RSView32 7.50 without key....
ThanX...
ThanX...
fatihgns
formfactor
Thank You very much!numpoochong wrote:# Rockwell Software License File
I have an activated RSView32 7.60 for this method. The *.lic text is legal(!!!) activation!
If you want to use this method, you must to change MAC address for your Network Adapter from value by default to the HOSTID (as sample for this: 001d9246b028), or use another application for emulate network adapters (as sample: VirtNet)
dhullett
I have tried this a few times with no success? Im running a VM so changing the mac address was no problem. In factory talk activations manager my host bindings are showing the correct mac address but still shows N/A on available and used and borrow under the activations tab. any ideas?
vivion
I also suffered for a long time with activation. Then I installed everything on Windows 10 and installed
"Imdisk Virtual Disk Driver Toolkit" a disk emulator for x64. And everything works great.
Cristiano14
I'm looking for Factorytalk View Studio Site Edition v9.00.00, does anyone have it? Can someone help me?
Thanks!
Thanks!
