[?]: read project from 256k EPROM of dead OP30/B
zhal
Post by zhal »
Hello, All!
I'm have dead (realy dead) OP30/B, and now i try to find any posibilities for a read project from 256k EPROM.
Maybe somebody can say we - what software i need for this?
graf_STEP7
Re: [?]: read project from 256k EPROM of dead OP30/B
Post by graf_STEP7 »
Hi
zhal wrote:I'm have dead (realy dead) OP30/B, and now i try to find any posibilities for a read project from 256k EPROM.
You need an eprom-Burner.
Software is normaly with this burner.
Urgend:
Read number/Typ from your EPROM.
Check, if the Burner can Read/Write this EPROMS.
Yes, you can "READ" this informations.
But all infos are in HEX-Codes. (Can you read/interprete this Code)
My TIP:
Bye an old "OP30/B", change the EPROMS.
Look, if the "OP30" is working fine.
If working correct:
Make a Picture from all "Displays/Informations".
Disconnect the CPU each "Side", Display(OP30) say can no read --> as.example: DB100.dbx12
regard graf_step7
zhal
Post by zhal »
Hello!
I'm have USB S5/S7 Promer, and in software S5Eprom I haven't code of my EPROM module. Also in module list is only moduls till 128kB. EPROM of OP30/B is specific: it have one EPROM with OP30 firmware with size 265kB, and one flash EPROM for a project (256kB also). Total size of eprom module is 512Kb. And i don't know how i can make HEX dump of this module...
About old OP30/B panel - it is big problem for find it in Ukraine.
PS I can make HEX dump with code 124, but it is only 128Kb. When i have selected other types EPROM with 128kb size - S5Eprom say "incorrect module"
I Have screens in manual. But i need know what DBs and with what structure used for visualisation...
graf_STEP7
Hi
zhal wrote: Make a Picture from all "Displays/Informations".
Make it for full working.
Select a side.
Remove the cable --> now he say, DB12.DBD20 not readable.
(Normaly all variable, he will read and display from this selected "Side" )
zhal wrote: About old OP30/B panel - it is big problem for find it in Ukraine.
You can find it in UK / Europe.
Repaire is possible too.
Look to EBAY. -->
http://www.ebay.de/itm/Siemens-OP30-B-6 ... 3cc03a91cf
