Good day.
Hello, please advice. I have got PLC CQM1 CPU21 a AD041 for home automation. AD041 is set to 0-10V range.
I have a sensor that gives the output 0-10V (0V = -50 ˚C, 10V=150 ˚C). I do not know, how I do it to showed the current ˚C particular under 0˚C (minus)
thank you
[?]: scale Analog Input Omron CQM1 + AD041
mohdabshr
Re: [?]: scale Analog Input Omron CQM1 + AD041
Hi I face this problem before how to find the analog reading in CQM1 so my advice as to search in internet search for file(W238_E1_10.pdf) look at page 97 to see how scaling analog input and to find DM that the programmer used and you can monitor it .which program you are used is cx-one or syswin3.4?
GWEN
Hi, I use cx-programmer. Thanks for advice, I try to search this file.
