[?]: How i can communication with panel view 600
Antwan_jacoup
I have a program with panel builder for panel view 600 and i can't communicate with it how i can download it
dehell
Re: [?]: How i can communication with panel view 600
Which model of panel view 600?
Which type of communication, do you use?serial?ethernet?other...
Antwan_jacoup
model 2711-B6C20 PV600 color key/touch , FRN 4.20-4.xxdehell wrote:Hi,
communication : ethernet
Ryzhij
Are you can access the configuration mode menu?
Quote from user manual (page 72)
Then you have the flash memory card you can download or upload project without RSLinx and any cables.
Then you have the RS232 2711-NC13(-NC14) cable
you can transfer application via RS-232 Printer/File Transfer Port.
Quote from user manual (page 36-37)
In configuration mode menu you can setup and/or check communication setting for downloading.The Configuration Mode menu appears on powerup if an application is not loaded or if the menu was last displayed prior to a reset or power down.
To access Configuration Mode on keypad terminals if an application is running, simultaneously press the Left and Right arrow keys on the terminal keypad.
To access Configuration Mode on touch screen terminals: ... press the filled box in the lower right corner of the screen during powerup.
On remote I/O, DH+, DF1, DeviceNet, EtherNet/IP, or ControlNet terminals, this port
also connects to the RS-232 port of a computer for transferring applications...
Antwan_jacoup
posting.php?mode=quote&f=12&p=49960#Ryzhij wrote:Are you can access the configuration mode menu?
Then you have the RS232 2711-NC13(-NC14) cableyou can transfer application via RS-232 Printer/File Transfer Port.
Thanks i do it
