[?]: how connect panel view C600 with micrologix 1100 ?
Antwan_jacoup
I need to connect panel view C600 with micrologix 1100 but HMI didn't connect and i need to know how i can make it
Ryzhij
Re: [?]: how connect panel view C600 with micrologix 1100 ?
Let me know catalog numbers your equipment - panel view C600 and micrologix 1100.
Antwan_jacoup
panel view C600 cat. No. 2711C-T6M Ser. C Rev. ARyzhij wrote:Let me know catalog numbers your equipment - panel view C600 and micrologix 1100.
Micrologix 1100 Cat. No. 1763-L16BBB Ser. B Rev. E
PLC program http://www.4shared.com/file/RDduoIVw/UP ... P-PLC.html
HMI program http://www.4shared.com/file/QBvoUgUE/UP00067-HMI.html
Ryzhij
First of all, you mast to setup channels into your micrologix 1100 programm.
And to do same for panel.( Your application UP00067-HMI is secured. Do you know the Login & Password for Designer right? )
Good luck!
Good luck!
Antwan_jacoup
i sent password and user name in PM to you and how i can setup channels in micrologix 1100 program & panelRyzhij wrote:First of all, you mast to setup channels into your micrologix 1100 programm.
Good luck!
Ryzhij
First of all, it should be noted that the direct link between the panel PVc-C600 and controller MicroLogix-1100 is only possible via the serial interface.
See pages 60-61 of PanelView Component HMI Terminals User Manual 2711C-UM001F-EN-P
Usually use RS232 DF1 protocol via cable 1761-CBL-PM02 (see there page 63).
I found it in your projects for the panel (and to the controller too) no serial port settings. This should be done.
Apply for this program RSLogix500 + RSLinx and PanelView_Component_DesignStation.
You also need to install the controller the same name in both projects.
I hope this file Screenshots.zip with illustrations
to help you.
Ethernet is used to connect the computer with the configuration of devices and for SCADA/DCS. About how to configure the Ethernet on pages 221-228 of MicroLogix 1100 Programmable Controllers User Manual 1763-UM001D-EN-P
and also on pages 44-47 of PanelView Component HMI Terminals User Manual 2711C-UM001F-EN-P
Good luck!
Good luck!
