Can somebody provide me with the cable pinouts needed to connect to the ultra 3000 drives series, i tried serial null modem, no luck, tried serial straight through, no luck.
If anyone has the pin out for the 'cn3' connector, would be helpful. seems to be a standard 9-pin d-shell connector.
Also when configuring the serial port setting, which settings should i use, baud rate 19200 7 data bits odd or even parity?
Thanks in advance!
[?]: Connecting to an Ultra 3000 servo drive with ultraware
Dan_Andric
Dan_Andric
Re: [?]: Connecting to an Ultra 3000 servo drive with ultraw
i figured it out, for whom it may be needed it is as following:
Pin 2 to 3
Pin 3 to 2
Pin 5 to 5
Baud rate 38400, 8 data bits- no parity
Pin 2 to 3
Pin 3 to 2
Pin 5 to 5
