Dear experts,
I used FC33 (s5time to IEC Time) to display the time interval set by the operator for a cyclic event (like for e.g turning of a Turn Table which turns after a specific time set by the operator which is stored in one of the data bloc , say DB1.DBW2 , declared as S5Time).
There are 2 display I/O fields on the WinCC screen - one for showing the time interval set by the operator and another one for showing the actual time remaining for the event to kick-off.
May I know what is the best/easiest way to achieve this? Is it wrong to go for the FC33 (s5time to IEC Time)?
Regards
[?]: Time display in WinCC Flex 2008
Info
- Faq & Info
Re: [?]: Time display in WinCC Flex 2008
http://support.automation.siemens.com/W ... n/26961516
