Dear All,
From the below list , What should be the order of installation after installing WinCC Flex 2008?
1) Wincc Flex 2008_SP2
2) Wincc Flex 2008_SP2_UPD 13
3) Wincc Flex 2008_HF3
And one more thing - I remember when I was having WinCC Flex 2005, I found my RAM memory is considerably utilized when WinCC Flex 2005 is in use.
Any specific reasons? .......... And shall I expect the same for WinCC Flex 2008 as well?
Plz advice.
Regards
[?]: WinCC Flex 2008 - Order of installation?
nashama
Umencho
Re: WinCC Flex 2008 - Order of installation?
I assumed you have only WinCC FLex 2008. So, start with it. Then SP2. But take in mind
You don't need Hotfix as is included in SP.
About the memory, I don't know how many GByte you have but there is need 2GB as recommendation. For me, multiplay this by 2 and 4 GB like a final result is "acceptable".
Then Update 13 for WinCC flexible 2008 Service Pack 2 . From the name is clear why is that.The Download of the service pack 2 requires an installed WinCC flexible 2008 or WinCC flexible 2008 SP1. It is not possible to install WinCC flexible with the download under Windows 7. For the installation under Windows 7 you need the the above-mentioned WinCC flexible DVD, which can be ordered from your Siemens contact person.
