Hi Friends
I'm new with Wincc Flex
I design a new project now and this is the first time I use Scripts
I had a strange problem:
scripts don't run when the screen loaded automatically , I have to switch to another screen then return again to the screen with the script to find the script executed
any help or any explanations plz ???????????
[?]: Scripts in Wincc Flex2008 - switch to another screen
alkharashy
Homeroid_BL
Re: [?]: Scripts in Wincc Flex2008 - switch to another scree
What is a trigger for a script?
Triaton
Hello, i had similar situation. My script was triggered by tag, which pulsed every second. But the same object, copied on two different screens and changing color depending on result of calculations of a script, behaved on a miscellaneous.
How it can be, if all tags are global in project? I dont know. I think its a bug of WCCF. The problem was solved by resaving the project and rebooting PC some times.
I am sorry for my/translator English.
Homeroid_BL
Scarch
The field that triggers to open the script must be read/write and the polling in cyclic mode (not under demand)
