[LINK]: channel configuration to connect slc5/3 with pv300
abbass 1
i need to know what is the plc channel configuration to connect slc5/3 with p v 300
Ryzhij
Re: [LINK]: channel configuration to connect slc5/3 with pv3
Settings link in the controller must match the settings in the PV300.
Of course, that type of interface should be the same.
If you are using a network interface, then of course the number of nodes to the controller and the panel should be different.
