Hello
Dlop wrote:Do you know about a manual of datadirect of 800xA 5.0? because, I need to develop
a report with current values of the controller. I try to do it, but the result is when I insert a data into the excel worksheet doesn't update automatically, until when I insert new aspect of a object, the worksheet it's updated.
Go ahead with 3BSE030322R5021_Sys_OperWPConfig.pdf (page 151, Basic Steps for Building and Executing a Report)
This document can be found in Start->All Programs->ABB Industrial IT 800xA->System->Reference Documentation->Operations (for SV5.0 with SP2)
Dlop wrote:P.D. When I try to login to DataDirect I need a user name, pass and hostname. In the manual in 800xA IM says:
User name: aid
pass: aid
hostname: localhost
I login with these data, but appears a message says "Doesn´t exists localhost"
Is display server installed and working?
Go Start->All Programs->ABB Industrial IT 800xA->Information Mgmt->Display Services->Server Status.
If no connection make the follow steps:
1. Start->All Programs->ABB Industrial IT 800xA->Information Mgmt->Display Services->Server->License Key.
2. Click "Update License!" button
3. Run DataDirect and try log in again...
regards, Linkinx64
