[?]: S2vd error with installation and vijeo designer 5.0
TrippleAce
Post by TrippleAce »
Hi all,
I have the s2vd software and vijeo designer 5.0.1.419 SP2,
but every time I try to install s2vd it gives me an error message saying that my vijeo designer is version 3.1 which is not the case.
Does anyone know how I can fix this??
Thanx guys... :shock:
vlad2006gr
Re: [?]: S2vd error with installation and vijeo designer 5.0
Post by vlad2006gr »
For vijeo designer 5.0 need version S2VJD 3.1. Which version do you have?
The compatibility between Switch2Vijeo tool version and Vijeo Designer versions for application program conversion is as tabulated below :
XBTL1000 Application Program-------Switch2Vijeo Version
VJD 4.5----------------------------------S2VJD 1.0
VJD 4.6----------------------------------S2VJD 2.0
VJD 4.6 Patch D------------------------S2VJD 2.1
VJD 4.7----------------------------------S2VJD 2.2
VJD 5.0----------------------------------S2VJD 3.0
VJD 5.0 SP1-----------------------------S2VJD 3.1
