[?]: download to touch screen TP177A old project
maher
Hi all
Please, I have siematic panel TP177A 5.7 ( 6AV6642-0AA11-0AX1 ), I need to upload the program from the previous panel and download it to the new one only uploading and downloading .
Please, tell me the required cable ( pin out ) to do this , the procedures of uploading and downloading , and the required program
OR can i use ( USP tO MPI adapter ) ?
Please, urgently
Maher
Please, urgently
Maher
maher
Re: [?]: download to touch screen TP177A old project
HI
I'll use the prosave program, But i need to know the details about the communication cable between pc and touch screen ( serial ( via RS232/PPI MULTI-MASTER CABLE )).
or can i use the USP to MPI adapter to establish the communication between PC & SCREEN.
Please, urgently.
Maher
Please, urgently.
Maher
doggydoo
The method I use is with a USB to USB transfer cable. You can get a Belkin one which will definately work. I use a clone type but whichever one you choose make sure you don't use the cables USB driver, use the USB Bulk Driver that is on a WinCC disk.
Just set the transfer mode at the panel to be USB and select USB in Prosave and away you go. You can also use this with WinCC if you have the project files.
Hope this helps.
Hope this helps.
maher
But i don't have this cable , I'm asking about if possible to use the USB TO MPI ADAPTER or not.doggydoo wrote:Hi,
Hope this helps.
Maher
Homeroid_BL
No, Maher. You can not use USB adapter becouse it needs 24VDC from PLC/HMI side and only CPU-DP ports and advanced HMI ports provide this 24VDC.
Use 232/PPI adapter (you can use Profilic USB/232 converter if your laptop has no serial ports). It work, tested.
maher
Homeroid_BL wrote:No, Maher. You can not use USB adapter becouse it needs 24VDC from PLC/HMI side and only CPU-DP ports and advanced HMI ports provide this 24VDC.
Excuse me , so can i use the 232/ppi adapter for all types of siemens HMI,
Regards
Maher
Homeroid_BL
I do not know about ALL, but with this cable I managed to update OS and transfer configuration for:
OP73 OP77 TP170 TP177 OP27 OP17 OP170
maher
Thanks a lot for your tips
could you choose for me the part number for RS232/PPI adapter to order it from siemens ( 6SE7901-3BF30-0XA0 OR 6ES7972-0CA10-0XA0 ), please ?
Maher
Maher
maher
I wait for your reply
Homeroid_BL
RS232/PPI cable is:
6ES7901-3CB30-0XA0
6ES7901-3CB30-0XA0
Homeroid_BL
Hint for future:
ALWAYS look at the proper manual:
In manual
SIMATIC HMI
HMI Device
TP 177A, TP 177B, OP 177B
(WinCC flexible)
Operating Instructions
at page 22:
In manual
SIMATIC HMI
HMI Device
(WinCC flexible)
at page 22:
"PC / PPI cable
You need the PC / PPI cable for TP 177A, TP 177B 6" and OP 177B to update the operating
system by resetting it to the factory settings. In addition, with TP 177B and OP 177B you can
use the cable for transferring purposes. Connect the PC/PPI cable to the RS 422/RS 485
interface. The cable converts the input signals to RS-232 signals.
The cable is not included the scope of delivery for the HMI device. The cable can be ordered
separately under the order number 6ES7 901-3CB30-0XA0.
Note
If the connection fails during the operating system update, set the system to a lower bit rate.
If you use a higher bit rate, you must use the PC / PPI cable release 3 or higher.
The version code is printed on the cable (e.g., "E stand 3" corresponds to version 3)."
maher
Excuse me , can do i transfer for the program by using prosave under windows ?
Maher
Maher
Homeroid_BL
When downloading application to HMI, you can select if upload will be possible. If uupload is possible, you can 'transfer back' application with WinCC Flex. If upload is not possible, you can make Backup using WinCC or Prosave. Backup IS NOT EDITABLE, it is just image of HMI memory.
So, depending of what you get (application or backup) you will choose a Transfer (form WinCC Flex, but update OS first), or you will chose Restore (from WinCC Flex od Prosave).
maher
Hi all
I'll take about the old HMI
I note something.The HMI doesn't response for any thing like ( transfer button ,start button,control mode ) so i can't enter to the transfer mode,also when I connect the old HMI to the machine no way to enter to screen only the starting screen , and it showes the alarm messages which belongs to the machine. so what does it mean?????????????
regards
Maher
regards
Maher
maher
Please, reply me
maher
Hi all again,
The supplier told me the program for the HMI is will be downloaded by the simatic manager ( that's means ) the program of the HMI is integrated in the SIMATIC MANAGER.
I found the HMI is connected on the profibus port .
could you let me know how can i download on this HMI through out the plc, please ??????????
Regards,
Maher
Regards,
Maher
usefi5961
Cable is very easy to build.
2-----------3
3-----------2
5-----------5
Pc to tp170b rs232 connector.
2-----------3
3-----------2
5-----------5
