Hi I was setting a expansion card for a TELEFLOW 3530-10B but I cant make the new serial port work ...
I'm using open BSI local view 5, ACCOL Workbench to make the new configuration ...
some Ideas please.
thnax a lot
[?]: settings for BRISTOL BABCOCK TELEFLOW 3530
Re: [?]: settings for BRISTOL BABCOCK TELEFLOW 3530
Hi there,
Do you have the manual?
Hi...
I made it work.
The port for the expansion card is the C port on the ACCOL worksbench, if we need a not full serial rs-232 it's must be jump the CD - DTS and the CTS-RTS signal keeping the j22 (expansion card) jumper on the 2-3 position.
I post this info in the case of some one have the same problem that I had
treefort Thanx for your interest
I made it work.
