Someone please me how can i communication with SLC 5 01/02/03 PLC ,
I am looking for a Good adapter device for trouble shooting and (SCADA) application with SLC PLC ..
please help me
Thanks in Advance
Dspic
[?]: AB SLC01 communication
neuhauser
Re: [?]: AB SLC01 communication
RSLinx for comm
RSLogix 500 for programming / Online viewing
If you have RSLinx OEM you can import / Export data into Excel or any other software that supports OPC/DDE (Wonderware, etc.)
If you want to use the RS485 port on a 5/01 - 5/03 you will need an adapter for a SLC500 - Serial -http://store.mrplc.com 1747-PIC $34.00 US
USB to 485 1747-UIC - $85.00 US
The Automation Store http://www.theautomationstore.com/index ... 8&Itemid=2
The 5/04 has DH+ for PLC5 comm (you can also use a 1756 RIO or 1756 DH/RIO for controllogix)
The 5/05 has Ethernet / Ethernet IP.
mesta1
I tried both and in my opinion 1747-UIC is better a lot.
I had a lot of troubles when i tried to configure the PIC
dspic
Dear friends thanks for the information
Dspic
Dspic
