Please help me fix this problem .
this version RSEmulate5 V5.00.08.00
thank and best regards
RSLogix Emulate 5 version 5.00.08 patch (build 5) to fix a crash when opening an RSLogix5 7.0 file.
Question
RSLogix Emulate 5 version 5.00.08.00 patch to fix a crash when opening an RSLogix5 7.00.00 file
Answer
Problem: When opening an RSP file that was created or saved in RSLogix 5 version 7.00.00 (CPR7), RSLogix Emulate 5 will crash.
Solution:
Installing the attached patch file (We532.exe file version 5.0.8.5), fixes the described problem.
Installation:
1.Shutdown RSLogix Emulate5
2.Unzip the attached file and copy it to the RSLogix Emulate5 folder (C:\Program Files\Rockwell Software\RSLogix Emulate 5 by default), overwriting the existing file.
3.Delete the configuration file in C:\WINDOWS\WINEMU5.INI
4.If necessary, restart RSLinx to clear EMU5X.DLL message.
Note: A newer patch is also available from Answer ID 37836 Click Here
