When you open the hardware configuration and go on-line, a small picture appears on the top left side of the original bitmap of the device. There are 2 bitmaps (OK and not OK), as in the attached picture. How can I edit such bitmaps or whatever they are, where are them?
Thanks! I will start playing with that library.
What I want is to change the small image and colours, nothing else. I have more than 60 stations in the hardware config and find difficult to look at them when there is some fault. I want 3 colours (green, red and grey). Green for OK, red for not OK and grey for not possible to check (for example, when the stations hang from a DP master on a CP342-5)
