I am doing a project with several CPU 315-2 PN/DP, these are reported with PROFINET industrial Ethernet, which does not confirm it in the manuals is the maximum distance that supports Ethernet network?
And if I can use switch to connect input / output ethernet next to each cpu?
Thanks in advance
