I would Like to Communicate SLC 503 and Citect Scada 7.10. I am new with Citect so i don't know how to configure communication between Citect and SLC 503. Please guide me and help me . thanks a lot for your help and sample if applicable (any even 3 demo switch)
thanks for your reply . But I am Still confusing. By the way, if i want to communicate SLC 503 and Citect, i should have 1747 KE module? any other ways, please!
Hi, have you tried to use the Express Wizard under the Communication tab, in Citect Project Editor? I haven't use the SLC 503 to communicate with Citect yet, but I guess the simplest solution is to communicate via ethernet network, which can be easily configured using the wizard. If you know the type of addressing for tags, everything should work fine!
