I spent 4 days looking for a MASTER DISK or any kind of activation for FactoryTalkView ME Station 5.00.00 (former RSView® ME Station™) but now luck!!
The only thing which works is to keep a Rockwell.Super.Key Floppy all the time in my laptop, but I prefer an activation to move it from floppy to laptop .
So,can you help me with a for a MASTER DISK or any kind of activation for FactoryTalkView ME Station 5.00.00 (former RSView® ME Station™) ?
Thanks,
Claudiu
[?]: Activation for FactoryTalkView ME Station
claudiu
Eng_Ali
Re: [?]: Activation for FactoryTalkView ME Station
if I understand youclaudiu wrote:Hi,
Thanks,
Claudiu
you have Floppy .............. So you can use move utility to move key to your hard disk ..
from start - all program - >rockwell software -> utility -> move Activation
regards
claudiu
Hi Eng_Ali,
Thank you for your answer!
I asume you are familiar with Rockwell.Super.Key Floppy ;it has some kind of manufactured keys which cannot be moved individually only the whole package.Unfortunately FactoryTalkView ME Station 5.00.00 will not activate even though I move the whole package.
However, I will not get the nag messsage about activation if I run FactoryTalkView ME Station 5.00.00 with floppy inserted.
You know that if you already transfer the activation on one pc you can run the same softwre on another pc IF YOU KEEP THE FLOPPY INSERTED.
so I assume the activation for FactoryTalkView ME Station 5.00.00 is not on Rockwell.Super.Key Floppy but only the capability to run with floppy inserted.
I woud be happy to get somehow a regular Master disk with activation for FactoryTalkView ME Station 5.00.00 to get rid of my USB floppy!!!
Thanks,
Claudiu
Thanks,
Claudiu
Eng_Ali
Hi
I working with FTV SE (not ME) without any problem by using Activation Key in this topic
viewtopic.php?f=41&t=6905
i thing you can use this
[dead] :/362456047/R ... vation.rar
claudiu
Thanks for the link!
I tried what you sugested but without floppy inserted I get the same message"
"...grace period of 7 days.
the following activations were not succesfully checked out;
RSVNE.500 , RSVME.250 , RSVME.RUN , RSVME.30, RSVME.15
