[?]: How communicate AB MicroLogix 1500 and PanelView + 600
hacynhan
I have PLC MicroLogix 1500 and PanelView Plus 600. How communicate them. I tryed RSLinx Enterprise but not successful. Help me
joker12
Re: [?]: How communicate AB MicroLogix 1500 and PanelView +
What Model is the 1500??? What is the Model of the PV600???
You need to supply a lot more info
cuongvcs
You can used RS-232 cable for communication between Micrologix 1500 and Panelview 600 plush.
Micrologix1500 which has no port RS-232?
Good luck
Good luck
eseq
What about ethernet, You can use serial connection as well. There is better solution ass Allen Bradley offers cheaper Panelview Compact and you can download ready plc/hmi code with manual how to connect them
Search on Allen Bradley Website for Connected Component Solution and Download Software( about 300mb )
Regards
Andy
http://www.automationengineering.co.uk
Regards
Andy
ERPal
Hello
communication between these two teams can be serial (RS232) with either DF1 or DH485 protocol.
the fact is that if you want to use your cable programming Micrologix to PV +, you will require a Null-Modem, so that the link is made
