The dear friends please help me .
I necessary the patch or crack for program winplc7 V4.34.
Or prompt what update Hardwareconfiguration in winplc V4.34
[?]: crack vipa soft program winplc7 V4.34
masvl
Schtiel
Re: [?]: crack vipa soft program winplc7 V4.34
Try solution for 4.32, it could work:
http://www.plcforum.uz.ua/viewtopic.php?p=29548#p29548
masvl
thank you for referency certainly, but I have not understood since use data
Can who will show concretely on example and drawing.
In brought answer was got break wiplc7 v4.32, but me necessary to break wiplc7 v4.34 and else Hardware-CFG remained former version V4.27.Can who knows what update Hardware-CFG for wiplc7 v4.32
shall much is thanked
All thanks study out. Renovations have loaded on bookmark Help->Updates for WinPLC7.
Jumped renovation hdw_sp_4_28a has started him,but has then updated file hardw in WinPLC7-V4.
Может кто нибудь покажет конкретно на примере и рисунках.
В приведенном ответе получилось поломать wiplc7 v4.32, но мне необходимо поломать wiplc7 v4.34 и еще Hardware-CFG остался прежней версии V4.27.Может кто знает как обновить Hardware-CFG для wiplc7 v4.32
спасибо за ссылку конечно, но я не понял так как пользоваться данным Hex-Editor где найти данные строки в WinPLC-S7 v4.32.
EmptyBrain
Try this for WinSPS-S7 v4.34 or WinPLC-S7 v4.34
-change Offsets in WS7V4.exe (with an Hex-Editor)
00000F8Dh from 756C to 9090
00000FA8h from 7451 to 9090
0000CA04h from 751F to EB1F
- make a backup before you change the offsets
- test it
EmptyBrain
- test it
EmptyBrain
