Hi there,
I'm trying to write a data from RS232 device into RSView32 tag.
When I use the VBA fom RSView32, all works OK, unfortunatelly I have to put a command click to do the instruction.
When I try to do this using VB 6.0, using timers (to do it in an automatic cycle), there appears an error:
"Run-time error '429': ActiveX component can't create object"
All my investigations and test say that the RSV Reference in the VB6.0 is the problem. I'm using the next instruction:
gtagDB("tag_name").value = x1
where x1 is a single variable (clean only numbers) obtained from RS232 device
Can some body help me in this?
Is there another idea to do it?
Thanks a lot in advance.
[?]: RSView32 and VB6.0 Write a tag into RSView
pplupe
