i have s7-300 plc. but i dont know what the software i need to use..
in this site i seach about siemen plc software but that to many model..
so can some one tell me what is the software i need to use..
thank for help
[?]: i dont know what the software i need to use S7-300 ?
Hi poteoib
Depending upon the hardware you want or have will depend upon the software package..
1. Very basic S7300 programming with Step 7 Lite which is free to download from Siemens. But be aware this is limited to hardware and does not support DP master, comms or special function modules.
2. Step 7 full version , is what i would recommend to be safe, but again this may possibly need bolt ons if the hardware requires it.
3. Step 7 professional has all the major packages integtral like programming, Simulation, SCL etc
Hope this helps
##~FlashY@~##
Hope this helps
##~FlashY@~##
Hi potetojb,
For the basic interface converter ("cable") that have 2 types
1. USB => MPI from siemens ord. no. 6ES7972-0CB20-0XA0
http://support.automation.siemens.com/W ... n/16983464
CP 5711 USB => Full Profibus/MPI 6GK1571-1AA00
http://support.automation.siemens.com/W ... n/34780027
or you can use compatible cable from 3rd party .It can use to programming
like the original siemens cable but can not communicate via profibus-dp
if you use only program via MPI programming port the compatible cable is Ok.
For the compatible cable converter you can call to : http://www.plc-siemens.com
1. USB => MPI compatible ord. no. 6ES7 972-0CB20-0XA0 (same as above original code but specified 3 rd party compatible.)
2. RS232 => MPI compatible ord. no. 6ES7 972-0CA23-0XA0
The price is cheaper than the original cable
Lucks.
Lucks.
