Can you send me (share to us ) sample program in STEP7 using 2 CPU (with command Send/Recv with CP343 ) like above ??,PLCSIM v5.4 SP3
http://support.automation.siemens.com/W ... n/36068796
https://support.automation.siemens.com/ ... 54_SP3.zip
51 MB-Multiple startability (multi-instance capability) and communication support between the simulated CPUs (simulation instance) !!!Service Pack 3 (SP3) for S7-PLCSIM V5.4 provides the following new functions:
-Optimized download by omitting the Node Browser
-Support of an additional PG/PC interface: PCinternal (local)
-Optimization of the communication between S7-PLCSIM and WinCC / WinCC flexible
-Indication of all CPU access addresses in the status line
I want to try with S7 PLCSIM V5.4 SP3
Thanks alot
