[?]: Protool & S7 200 226 Communication problem
Arthurious
Post by Arthurious »
Hello everybody,
Iam not able to connect to PLC S7 200 226, with protool even after following settings,.....
Iam using cable 6ES7 901-3CB30-0XA0.........
Iam connecting at 9.6 K baud,....
DIP is set according to this baud......
My DIP switch settings are as below:
1 2 3 4 5 6 7 8
0 1 0 0 0 0 0 0
I have also checked the DIP switch settings and they are Okay.
It also tried it with other bauds...
Everything is OK...still then donno where Iam making mistake........
few days back i was able to connect with above settings..........
the error message is
140003 --- General Connection error 0xce
pls give suggestions n comment,
regards,
auto_mitch
Post by auto_mitch »
Check the configuration in PC/PG Interface for Protool
