I would like to know if it is possible to view ladder logic, from a Micro Logic or SLC500, directly to a Panel View, for diagnosis purposes If so……..how
MG
As I know for today, the laptop has lowest cost then PanelView
And if you need diagnostic, you'll must to wrote special section in your PLC & Panel projects
The reason for asking the question is that I already have panel view 1000’s installed on my machines to control the functions of the machines. I wanted to simply get another function out of the panel view by adding a PLC diagnostic program, so I would not have to use my lap top to see the ladder logic status of the PLC.
I’m also asking………How would I accomplish this?
If the PV1000 is a Windows CE version, you can try to write a version of RSlogix500 if you're Very Very Very Good at programming in any of the higher level languages.
