[?]: Configuration serial cable Wago 750-841.
другие контроллеры
galmx
Post by galmx »
Hi.
I need your help:
somebody knows the configuration of the serial cable of programming of the PLC WAGO?,
i have the module 750-841.
Thanks.
care4u
Post by care4u »
We Have Cable , we Need Instruction for Uploading the Program from WAGO Controller to PC.
Pessimister
Re: [?]: Configuration serial cable Wago 750-841.
Post by Pessimister »
galmx wrote:somebody knows the configuration of the serial cable of programming of the PLC WAGO?
Yes.
1 - TxD (transmit data, output) - connect to T1IN pin of MAX232
2 - RxD (receive data, input) - connect to R1OUT pin of MAX232
3 - Vcc (power +5V) - can be the power source for MAX232
4 - GND (common)
care4u wrote:we Need Instruction for Uploading the Program from WAGO Controller to PC.
Just use ftp, but... There is no reason to upload compiled program from controller. You can't get the source code from it...
sasko
Post by sasko »
Is it possible connect wago RxD and TxD with com port on PC without MAX232 ?
THX
Dennis2004
Post by Dennis2004 »
Anyway you need to convert RS232 voltage levels to TTL.
You can adopt any known schematics, e.g.https://www.sparkfun.com/tutorials/215 (secon one)
https://remote-lab.net/serial-console-c ... ux-router/
http://www.uchobby.com/index.php/2007/0 ... explained/
Or use USB(with serial converter) or serial datacable from old mobile phone.
