Hello
I need to know what is the process for upload the program from creonics IMC-S/20x.
I have gml commander v 4.3 it's possible with this version upload the program from creonics,it's dangerous to do this I never did do it.....
[?]: How upload the program from creonics IMC-S/20x ?
JoseDave
oldarrior
Found a link might help.
http://www.plctalk.net/qanda/showthread.php?t=45404
Haven't been on S-Class for years, Unless you have the original GML all your going to get is script. But the guy brings up a couple of good points and my help you.
I can say you should still be able to upload the files and dump in a spare unit. And you should be able to tweek it in through the drive box but again without the original GML your limited to what you can do. Used to read and correct the script because early versions were limited but I'm out of practice.
Good luck
Good luck
