Did you try use another tpl.dll file from LicenceClient_2023.cp1 folder. After this i had opportunity to do apply changes (modification in Eplan settings and during chosing an article).
It is used this, but EPLAN .exe application error: 0xc0000142, trouble to provide the download address again, is it a system reason; please ask what version of the computer to install, thank you!
My goal is to open the EPLAN of win11 64 and close the program directly.5156PBK wrote: ↑Wed Nov 16, 2022 12:51 amIt is used this, but EPLAN .exe application error: 0xc0000142, trouble to provide the download address again, is it a system reason; please ask what version of the computer to install, thank you!
Does it work properly after restarting? Or after some time the same situation?lucasp016 wrote: ↑Wed Nov 16, 2022 7:14 pmHello friends, I've been testing this crack for a while, however, I noticed that it has some problems, when running the program it works normally, however, after a while the confirm button stops working, so it is necessary to close everything and open everything again.
Вы вставили и заменили необходимые файлы, как написано в инструкции? Стабильного лекарства для 2023 сейчас нету. Ждем...
It works after restarting, however, after a while the problems again. I'm wanting to get out of 2022 because it's giving problems with recent drivers from AMDDr_zlo wrote: ↑Thu Nov 17, 2022 9:18 amDoes it work properly after restarting? Or after some time the same situation?lucasp016 wrote: ↑Wed Nov 16, 2022 7:14 pmHello friends, I've been testing this crack for a while, however, I noticed that it has some problems, when running the program it works normally, however, after a while the confirm button stops working, so it is necessary to close everything and open everything again.
I also find after some times there is no possibility do doubling of symbol (device). Key D doesn't work. During project reservation auxiliary window just close and nothing happen. Sometimes Eplan doesn't open .zw1 format. Waiting for help from chaos363 or another specialistes.Вы вставили и заменили необходимые файлы, как написано в инструкции? Стабильного лекарства для 2023 сейчас нету. Ждем...
В самом Eplanе (2022) заходишь в Файл/Справка/Поддержка и обновление/Dоwnload manager
No valid XML file with component listing... Область загрузки недоступна. Вот такое мне выдает.Alex Pro wrote: ↑Sat Nov 19, 2022 6:00 amВ самом Eplanе (2022) заходишь в Файл/Справка/Поддержка и обновление/Dоwnload manager
там все обновления (SP и Update) для текущей версии eplan, для 2022 уже вышел 5й апдейт, работает с EPLAN_Patch_1_0_5 от chaos363 (смотри тут оригинал https://disk.yandex.ru/d/pMnlq7gDgm5U-A, с моими доп.
https://disk.yandex.ru/d/yufbaq_z9xLSKQ)
Странно, попробуй взять отсюдаВладимир wrote: ↑Mon Nov 21, 2022 5:39 pmNo valid XML file with component listing... Область загрузки недоступна. Вот такое мне выдает.Alex Pro wrote: ↑Sat Nov 19, 2022 6:00 amВ самом Eplanе (2022) заходишь в Файл/Справка/Поддержка и обновление/Dоwnload manager
Вот это (п.1 и 5) дла Cloud работает:
Для 2023 нужен новый vcruntime140.dll, иначе eplan запускается, и через некоторое время (у меня около минуты) нельзя что либо поменять или сохранитьВладимир wrote: ↑Mon Nov 28, 2022 11:40 amЭто я все по кругу несколько раз проделывал.
с 23-м не прокатило, я даже так и не понял, что я не сделал, но явно что-то не сделал. Но там версии лицензий не совпадали.
И тут после апдейта в клауд ломится и не открывается. Файлы проверил дважды. Все внесено, все вписано. Попробую еще разок завтра, внимательнее проверю все.... Посмотрим.
Вот сегодня звезды чуть по другому выстроились и все получилось. Спасибо еще раз. Апдейт заработал пока.Alex Pro wrote: ↑Mon Nov 28, 2022 4:39 pmДля 2023 нужен новый vcruntime140.dll, иначе eplan запускается, и через некоторое время (у меня около минуты) нельзя что либо поменять или сохранитьВладимир wrote: ↑Mon Nov 28, 2022 11:40 amЭто я все по кругу несколько раз проделывал.
Ждем помощи от chaos363!!!
Проверьте функционирование программы на примере вывода свойств у любого из элементов, например <20248> для сегмента маршрутизации. В какой-то момент становится невозможно вывести новые свойства и программа перестаёт обрабатывать данные. Раньше это лечилось зменой имени в кряке с chaos363 на любое другое, сейчас в 1.05 это не срабатывает.Владимир wrote: ↑Tue Nov 29, 2022 5:34 amВот сегодня звезды чуть по другому выстроились и все получилось. Спасибо еще раз. Апдейт заработал пока.Alex Pro wrote: ↑Mon Nov 28, 2022 4:39 pmДля 2023 нужен новый vcruntime140.dll, иначе eplan запускается, и через некоторое время (у меня около минуты) нельзя что либо поменять или сохранитьВладимир wrote: ↑Mon Nov 28, 2022 11:40 amЭто я все по кругу несколько раз проделывал.
Я не настолько крутой специалист в этой программе. Какой элемент надо проверить? Любое изделие в проекте или вообще любой: лист, изделие, соединение?floydvc wrote: ↑Tue Nov 29, 2022 6:26 am
Не обязательно это свойство искать, попробуйте вывести любые свойства для точки определения соединения на вкладке "Точка определения соединения" далее в поле "Свойства" нажав знак "+" и выберите, например "Доп. поле [1] <20901 1>, именно вывести, внести в поле данные любые, нажать применить, ОК, закрыть вкладку и затем снова открыть свойства точки определения соединения и проверить, на месте ли выведенное свойство и заполененное значениеВладимир wrote: ↑Tue Nov 29, 2022 9:42 amЯ не настолько крутой специалист в этой программе. Какой элемент надо проверить? Любое изделие в проекте или вообще любой: лист, изделие, соединение?floydvc wrote: ↑Tue Nov 29, 2022 6:26 am
И как найти номер свойства 20248? В версии 2022 номера эти я не смог найти.
Для 2023 версии подтверждаю, как и писали коллеги выше, обработка свойств прекращается через некоторое время (примерно несколько минут) и дальше работать в программе невозможно. Испробовал все кряки предоставленные на ресурсе.Владимир wrote: ↑Wed Nov 30, 2022 4:57 pmМы с вами точно одну и ту же версию обсуждаем?
Есть ТОС, через ПКМ вызываем Свойства, жмем на вкладку отображение, добавляем поле Доп.поле(1), и где его заполнить после этого? Свойства его да, тут же на вкладке, а где его содержимое то заполняется? Оно на листе не выводится никак... Поля ввода его содержимого не добавляется.
Я, похоже, совсем чайник в этой программе. Надеюсь, что "глючные" свойства работы мне еще долго не будут доступны...
Спасибо.
Подходит, update 6 работает без тормозов!floydvc wrote: ↑Fri Dec 02, 2022 5:46 am1. Заметил, что в 2022 update 5 в процессе работы периодически происходит задержка работы программы на несколько секунд, подвисание, когда прога не реагирует, затем всё нормально и через несколько минут повторяется. Отзовитесь, кто наблюдал подобное и смог ли вылечить?
2. На 2022 update 4 всё работало корректно, без зависаний. Но я не смог откатиться и переустановить 2022 update 4, т.к. при накатывании версии v2022.0.3.17561 далее он позволяет обновиться в Dowmload Manager только до v2022.0.3.17808 update 5. Существует ли способ поставить 2022 с необходимым мне update'ом?
3. Сегодня вышла версия v2022.0.3.17835 update 6. Поставил ли его кто-то, crack подходит?
Не сосем так. 5й больше 1го, а 6й меньше потому как в нем нет EPLAN License Clientа, он тот-же что и в 5м. На самом деле это всего лишь архивы UD вместе с ("мусором" ) языковЫми GUI, так-что сами UD увеличиваются в соответствии с номером UD.Владимир wrote: ↑Sat Dec 03, 2022 11:10 am
Заметил, что апдейт 1 больше по размеру, чем апдейт 5 или 6. Апдейты вообще кумулятивные, накопительные обновления или надо все ставить?
Подтверждаю, у меня update 6 также корректно заработал.Alex Pro wrote: ↑Fri Dec 02, 2022 8:07 pmПодходит, update 6 работает без тормозов!floydvc wrote: ↑Fri Dec 02, 2022 5:46 am1. Заметил, что в 2022 update 5 в процессе работы периодически происходит задержка работы программы на несколько секунд, подвисание, когда прога не реагирует, затем всё нормально и через несколько минут повторяется. Отзовитесь, кто наблюдал подобное и смог ли вылечить?
it is possible that to work with the API in eplan, you need eplan electric P8 professional + an additional API, the demo version with the API will not workredline147 wrote: ↑Tue Dec 20, 2022 11:40 amHi chaos, thanks for your work.
I found a problem when I try to debug a script.
I have installed Eplan 2022 with Update 6.
License version (Client): 2022.0.3.364
I use your software version 1.0.5.
With this configuration.
System_48=EPLAN Demo System
Module_30107=VersionAll
Module_30106=EPLAN Employee
Module_1599=Language: All
Module_30108=No Identity Check
Module_1450=Skip Identity Check
If i try to attach Visual Studio 2022-2019 to EPLAN.exe process it close EPLAN.exe.
Visual Studio shows: El programa '[3460] EPLAN.exe: Seguimiento de programa' terminó con código 0 (0x0).
I try with a legal license and the same script, and Visual Studio can be attached to EPLAN.exe and stop at debug point.
An example of the script and the process to attach debugger: https://suplanus.de/script-debugging/
Thanks for all.
Объясните, пожалуйста, а как так получается, что следуя инструкциям в файле readme из указанного кряка, ни в какую не получается "запустить" еплан 2023? Уже полсотни раз и "впрямую" и на виртуалках разных: данный файл лицензии не подходит к текущей версии еплан. Только у меня такие кривые руки или кто-то тоже так же мучался и справился?
