Тools, Elcad, Eplan, ...
h4rdw4re
Post by h4rdw4re » Wed Aug 18, 2021 7:27 pm
SStasL wrote:
Fri Jul 02, 2021 5:18 am
In Software by chaos, you can use checkboxes to choice the required modules and save your choice to .tpl
Did you manage to get Ultimate license using available modules?
I tried few times and only can manage to get Component Manufacturer.
If someone made .tpl with Ultimate license please explain how did you manage it and, if possible, share your .tpl file.
I have keygen 1.01 with Ultimate.tpl but it just don't work.
EPLSG
Post by EPLSG » Thu Sep 09, 2021 8:00 pm
Could you share patch 1.02 again?
File was removed
EPLSG
Post by EPLSG » Sun Sep 12, 2021 8:24 am
Thanks so much guys
rgaferus
Post by rgaferus » Tue Sep 14, 2021 7:29 am
Please share the latest hot fix for version 2.8. (HF 4 sort of.) Thanks in advance
Abigail_Dea
Post by Abigail_Dea » Tue Sep 14, 2021 8:27 am
Could somebody please share the macros folder (files ) for the EPLAN v2.9 SP1, mine was corrupted when I tried to open with other window apps. Appreciate if you could share the build in macros folder, installed during system installation. ( Sorry if this is off-topic ... (offtop) )
The folder is located in C>Users>Public>EPLAN>Data>Macros> " Filename "> Macros File....
My last option is to re-install again the P8, but hope it will not come to that direction.
Thank you for your assistance.
Regards,
Abigail
UzOdin
Post by UzOdin » Tue Sep 14, 2021 8:55 am
EPLAN Download Manager
Since EPLAN Platform, Version 2.4 all Hotfixes are available directly via the EPLAN Download Manager. For installation simply choose the menu item Help > EPLAN Download Manager.
TheDuke
Post by TheDuke » Tue Sep 14, 2021 4:57 pm
You have the EPLAN Data on your harddisk.
Look here: C:\ProgramData\EPLAN\O_Data\Platform Data\2.9.4\Macros
You can sync this in EPLAN https://eplan.help/help/platform/2.9/en ... enabgleich
Look for sync from "EPLAN master data" to "System master data"
Frischling007
Post by Frischling007 » Mon Sep 20, 2021 11:37 am
EPLAN 2022 is out now. Is there already a crack?
gdbird
Post by gdbird » Mon Sep 20, 2021 3:31 pm
I tried to use keygen to activate EPLAN 2022, but it failed. Even though I loaded EPLAN 2022's EplanCommon.lit, it seems that EPLAN 2020 has changed the HWID encryption method, so the keygen needs to be upgraded. Looking forward to chaos363 to upgrade. The default path of EplanCommon.lit in EPLAN 2022 is C:\ProgramData\EPLAN\ELC
peewee
Post by peewee » Mon Sep 20, 2021 3:54 pm
they are new licence manager 2022.03.321 in P8 2.9 was 9.1.17.12300
gdbird
Post by gdbird » Mon Sep 20, 2021 4:15 pm
yes, I just use this tool EPlanLicenseManager.exe to generate HWID, it same to EPlanKeygen.exe. may be vcruntime140.dll need to update to adapt tp eplan 2022.
gdbird
Post by gdbird » Tue Sep 21, 2021 4:33 am
EPLAN Electric P8 2022 download
viewtopic.php?f=7&t=28735
(welc)
gdbird
Post by gdbird » Tue Sep 21, 2021 9:17 am
chaos363
Post by chaos363 » Tue Sep 21, 2021 7:55 pm
:mrgreen:
https://gofile.io/d/CMBfyo
vcruntime140.dll has changed and template has been expanded for the new options.
leewheel
Post by leewheel » Tue Sep 21, 2021 11:16 pm
Thanks !!!!!
leewheel
Post by leewheel » Tue Sep 21, 2021 11:17 pm
EPLAN 2022
https://gofile.io/d/ZTY9yg
Is there Propanel and Fluid?
s1921707
Post by s1921707 » Wed Sep 22, 2021 12:20 am
“You must log in to epulse at 7:40:18 on October 2, 2021 at the latest so that you can continue to use the EPLAN solution.”
Is there a solution?
Frischling007
Post by Frischling007 » Wed Sep 22, 2021 4:53 am
thanks, but the v2.9 no longer works? please help. (oo)
chaos363
Post by chaos363 » Wed Sep 22, 2021 5:11 am
Replace all vcruntime140.dll. The new license client is used everywhere (also 2.8 etc).
chaos363
Post by chaos363 » Wed Sep 22, 2021 5:14 am
I don't have a solution for it now. Let's see what happens after the process.
s1921707
Post by s1921707 » Wed Sep 22, 2021 6:24 am
After changing the system time
“The period for starting EPLAN without logging in to epulse has expired. Restart EPLAN and log in to epulse.”
EPLSG
Post by EPLSG » Wed Sep 22, 2021 1:05 pm
Sorry,I don't understand.
Medicine for Eplan 2.9 will be works after 2 <october?
I don't understando what I have to do to use Eplan 2.9.
Please Help me
Currently Version 2.9 works fine on my station.
Centurio
Post by Centurio » Wed Sep 22, 2021 1:21 pm
Not able to download the new patch.
Please help me with a new link.
Many thanks in advance!
Jake1
Post by Jake1 » Wed Sep 22, 2021 3:19 pm
Please Help me
You must not change to 2022, if 2.9 works for you, all is fine!
Wait with upgrade to 2022 till the medicine disable the necessary login for EPLAN ePulse.
Jake1
Post by Jake1 » Wed Sep 22, 2021 3:21 pm
Link for the patch from chaos still works, no problem to download.
leewheel
Post by leewheel » Thu Sep 23, 2021 2:29 am
Can you please test this software Run as date
https://www.nirsoft.net/utils/run_as_date.html
Jake1
Post by Jake1 » Thu Sep 23, 2021 6:49 pm
The program can work, why not, but its not very smart and the message to login into ePulse ruins my good mood
(wow)
s1921707
Post by s1921707 » Fri Sep 24, 2021 3:16 am
Tested, no effect
I don't know which running file epluse logs in to
gdbird
Post by gdbird » Fri Sep 24, 2021 1:49 pm
This is the app for eplus create EID. There should have a crack for bypass this or have a fake server.
Eplan.IdentityClient.exe
C:\Program Files\EPLAN\Common\IdentityClient\Eplan.IdentityClient.exe
The IdentityClient.log you can find in this path
C:\Users\Public\EPLAN\IdentityClient
Any way, we should crack and write AuthenticationTime .
2021-09-24 21:32:32,169 INFO - EAuthorization.Exit - GracePeriodStartTime=08/27/2020 21:26:06 +08:00, AuthenticationTime=01/01/0001 00:00:00 +00:00, Sub=, OrganizationId=
(not_allow)
s1921707
Post by s1921707 » Sat Sep 25, 2021 3:53 am
verygood!
faralway
Post by faralway » Tue Sep 28, 2021 2:15 am
:mrgreen:
Thanks so much for sharing !
rajaguru
Post by rajaguru » Tue Sep 28, 2021 3:10 am
Can you please provide Setup for Eplan V2.8 with latest Hotfix (2.8.3 or more)?
MuratKarilci
Post by MuratKarilci » Tue Sep 28, 2021 4:33 am
Thank you chaos363 (pgood) ,
If you solve the problem of ePluse, the work is done and you have helped a lot. (clap)
rajaguru
Post by rajaguru » Tue Sep 28, 2021 10:56 am
Can you please elaborate, how to do this step?
Thanks in advance. (tyou)
UzOdin
Post by UzOdin » Tue Sep 28, 2021 12:21 pm
EPLAN_Electric_P8_2.8
https://gofile.io/d/WRlU6j
Cleber_st
Post by Cleber_st » Tue Sep 28, 2021 2:45 pm
Does anyone know if this work on Windows Server 2012 R2 ??
I tried once a month ago, but when all process was finished and I run the program there wasn't any version that I could choose.
Jake1
Post by Jake1 » Tue Sep 28, 2021 3:35 pm
Good plan! (clap)
lets hope chaos6363 is on our side and he can disable this senseless ePulse shit!
kekusian
Post by kekusian » Thu Sep 30, 2021 8:12 am
Please help! Which systems and modules should i use for Harness proD 2.9?
debugman
Post by debugman » Thu Oct 07, 2021 6:53 am
:mrgreen:
Has the trial time of eplan2022 been cracked? There is also a login pop-up window. Can you close it?
Jake1
Post by Jake1 » Thu Oct 07, 2021 7:44 am
We still wait for the "ePulse crack" :(
Crack for licence works fine, only this ePulse sucks and we cant use the new EPLAN 2022.
I have a legal mail adress for ePulse, but its not the best idea to use a legal mail adress with an illegal EPLAN licence 8)
Lukha
Post by Lukha » Thu Oct 07, 2021 11:29 am
Hi everyone,
I've downloaded and installed Eplan electric P8 2.8.3 and I have keygen 1.03.
I'm running Windows 10 Professional
Can someone please teamviewer onto my laptop and help get Eplan up and running?
Private message me please.
Lukha
EPLSG
Post by EPLSG » Fri Oct 08, 2021 6:06 am
Lukha
You wrote about Keygen 1.03.
where can I find it?
Jake1
Post by Jake1 » Fri Oct 08, 2021 6:48 am
Hi, here on page 8 from chaos363, Date Tue Sep 21, 2021
Is still online (pgood)
EPLSG
Post by EPLSG » Fri Oct 08, 2021 8:56 pm
Great Jobs.
Thanks a Lot Jake1
Jake1
Post by Jake1 » Sun Oct 10, 2021 8:46 am
All thanks goes to Chaos363, not to me :)
EPLSG
Post by EPLSG » Mon Oct 11, 2021 9:13 am
Yes of course, I agree.
Chaos363 Number one,for us you are a teacher. :D :D :D
wiser87
Post by wiser87 » Sat Oct 16, 2021 4:50 am
Hello! Could you give me a link mega.nz for downloading the following programs
Eplan Engineering Configuration One V2.9 SP1
Eplan Congineer 2.9 SP1
Eplan 2.9 SP1 update 6
Thank You
leewheel
Post by leewheel » Fri Oct 22, 2021 1:58 am
(not_allow)
This is the final solution!! (pgood)
s1921707
Post by s1921707 » Sat Oct 23, 2021 12:49 pm
EPLAN_Smart_Wiring_2022
https://gofile.io/d/WEh7Tv
This can't be cracked
