[REQUEST] Image (back-up) of 32GB SIMATIC S7 Memory Card
Petrozawodsk
Post by Petrozawodsk » Thu Jan 14, 2021 9:35 pm
Hello.
Can anybody help with copy image (back-up) of 32GB SIMATIC S7 Memory SD Card?
Art No. 6ES7954-8LT02-0AA0 or 6ES7954-8LT03-0AA0.
Need disk sector-by-sector image, created by WinHex for example.
Russian wrote: Всем привет.
Прошу помочь с образом семёновской цпушной SD карты на 32ГБ.
Пойдёт любой формат дампа, лишь бы был полный (с первого, до последнего сектора).
Спасибо заранее.
SIMATIC S7, memory cards for S7-1x 00 CPU, 3.3V Flash, 32GB
Re: [REQUEST] Image of 32 GB SIMATIC S7 Memory Card
Post by CoMod » Fri Jan 15, 2021 9:26 am
it won't help you - someone else's dump won't work :(
for S7 SD cards, the checksum is calculated from the hard-coded hardware serial number
это тебе не поможет - чужой дамп не подойдёт :(
для S7 SD карт контрольная сумма вычисляется по жёстко записанному аппаратному серийному номеру
http://s7detali.narod.ru/MMC/SMC.html
попробуй отформатировать в CPU =Formatting of a SIMATIC memory card may only be carried out in a CPU.
Deleting the contents of the SIMATIC memory card You have the following options for deleting the contents of the SIMATIC memory card:
● delete files using Windows Explorer
● format with STEP 7 Note If you format the card with Windows utilities, you will render the SIMATIC memory card unusable as a storage medium for a CPU.
Deletion of files and folders is permitted, with the exception of the "__LOG__" and "crdinfo.bin" system files.
These are required by the CPU. If you delete these files, then you will no longer be able to use the SIMATIC memory card with the CPU. If the "__LOG__" and "crdinfo.bin" system files have been deleted, format the SIMATIC memory card as described in the following section.
Formatting a SIMATIC memory card
Note
Formatting of a SIMATIC memory card may only be carried out in a CPU. Otherwise the SIMATIC memory card cannot be used in the S7-1500 CPUs.
If you want to format the SIMATIC memory card using STEP 7, an online connection to the relevant CPU must exist. The relevant CPU is in the STOP mode.
Proceed as follows to format a SIMATIC memory card:
1. Open the Online and Diagnostics view of the CPU (either from the project context or via "Accessible devices").
2. In the "Functions" folder, select the "Format memory card" group.
3. Click the "Format" button.
4. Click "Yes" in response to the confirmation prompt.
Result:
● The SIMATIC memory card is formatted for use in S7-1500 CPUs
● The data on the CPU are deleted with the exception of the IP address
Petrozawodsk
Post by Petrozawodsk » Fri Jan 15, 2021 11:08 am
...попробуй отформатировать в CPU...
Спасибо.
Но вопрос всё-таки открытый.
У меня нет такой карты, мне нужна инфа с такой большой карты.
Хочу разобраться в структуре данных такой карты.
englisch wrote:I don't have card. I need information, what exactly is located inside it.
So I need disk image for education purposes.
Can anybody make copy?
To share it - you can make archive to reduce final size.
Post by CoMod » Fri Jan 15, 2021 1:02 pm
the structure there is simple - there is a directory with service files
and a copy of the service file data at the end of the address space
understand on the WinHex images http://s7detali.narod.ru/MMC/SMC.html
структура там простая - есть каталог со служебными файлами
и копия данных служебного файла в конце адресного пространства
понимай на выложенных образах http://s7detali.narod.ru/MMC/SMC.html
24 MB S7img 	S7-1200-24MB.S7img				real size 32 MB
24 MB WinHex 	6ES7954-8LF02-0AA0_24_MB_SMC.ZIP		real size 32 MB
		6ES7954-8LF03-0AA0_24_MB.ZIP (3 cards) 		real size 32 MB
4 MB WinHex 	6ES7954-8LC02-0AA0.zip				real size 8 MB
2 GB WinHex 	6ES7954-8LP02-0AA0_2GB_SMC_0098cb7108.zip 	real size 2 GB
Petrozawodsk
Re: [REQUEST] Image (back-up) of 256MB/2GB/32GB SIMATIC S7 Memory Card
Post by Petrozawodsk » Sun Jan 17, 2021 6:30 pm
Я для начала изучил инет, и детали на народе тоже. А потом уже запостил топик.
Мне непонятны остались некоторые поля, думаю с большими флешками разберу остальные.
english wrote:Im already studied that link before. I need extra info from bigger one.
Post by CoMod » Sun Jan 17, 2021 9:58 pm
а как ты представляешь несжатый образ в 32 гигабайта ? Винда его выдержит ?
на руках есть на 2 ГБ, и несколько 24 МБ.
Petrozawodsk
Post by Petrozawodsk » Mon Jan 18, 2021 6:49 am
Выдержит. Винхекс его всеравно частями грузит в память.
А если его надо смонтировать, я обычно винхексом на флешку через картридер пишу и винда подтягивает.
Плюс Винхекс может парсить образ сам и файлики оттуда брать, но он как-то плохо это делает, поэтому я обычно образ на флешку нарезаю.
Не могли бы вы с ваших карт образа сделать, ну или хотя бы "crdinfo.bin" с них выложить?
При одних и тех же заказных, внутри оказываются разные данные. Похоже для семёна разные конторы флехи штампуют.
Обычно образа по большей части пустые, так что после 7Zip они очень маленькие.
Чутка доп. инфы по картам тут
Petrozawodsk
Re: [REQUEST] Image (back-up) of 32GB SIMATIC S7 Memory Card
Post by Petrozawodsk » Fri Feb 05, 2021 8:18 pm
English wrote:Does anybody have 6AV6881-0AP40-0AA0 or 6AV6881-0AQ40-0AA0 - SIMATIC HMI MEMORY CARD, 32GB?
I need image copy of it, or at least "crdinfo.bin" file from the root of flash disk (hidden, system file).
Может есть у кого такие флешки?
Нужен образ, ну или на крайний случай скрытый системный файл из корня диска "crdinfo.bin".
https://support.industry.siemens.com/cs ... u&lc=ru-RU
(6AV6881-0AP40-0AA0, 6AV6881-0AQ40-0AA0 - SIMATIC HMI MEMORY CARD, 32GB)
Post by Dfcz » Sun Feb 07, 2021 4:55 pm
Там есть еще служебный сектор, который обычным кардридером не прочитать.
kaitoukid_1997
Post by kaitoukid_1997 » Mon Aug 15, 2022 7:20 am
Do you have img. copy file yet?
