[About]: Step7 v5.5 Block Privacy v1.0
In new version 5.5 not visible password under stars .
Re: [INFO]: Simatic RoadMap - whats new in Step7 v5.5, PCS7.
There is a new feature in Step7 v. 5.5 called S7 Block Privacy (installation is available at CD_2\Optional Components\S7 Block Privacy).
As I understand, it is an alternative to obsolete "Know-How protection". The question is if it's possible to open blocks that are protected with S7 Block Privacy without knowledge of a password.
- Forum Community
Step7 V5.5 new S7-Block Privacy
http://www.youtube.com/watch?v=XW5hcWRdB7Q
The program-code will be encrypted with 128 Bit on the PG, encoded transmitted and decrypted on the controller.
BlockPrivacy_README wrote:SIMATIC S7 Block Privacy V1.0
2.1 General Notes
· The call for the S7 Block Privacy application is integrated in the SIMATIC Manager. It is always called in the shortcut menu of the block folder (menu command "Block Privacy..."), this means that the STEP 7 project and the S7 program are specified for the called S7 Block Privacy instance. If an S7 Block Privacy instance exists when you call S7 Block Privacy for a different S7 program, the new parameters (STEP 7 project and S7 program) are passed to the running program.
· S7 Block Privacy supports function blocks(FB) and functions (FC).
· The CPU must have at least the following version:
o CPU 3xx: firmware version V3.2 or higher
o CPU 4xx: firmware version V6.0 or higher
· Following encryption, the encrypted blocks are available in the databases of a STEP 7 project.
· Encrypted blocks cannot be processed with earlier versions STEP 7 (call, instantiation etc.).
· The S7 Block Privacy application works only in conjunction with the SIMATIC Manager. Exiting the SIMATIC Manager also exits S7 Block Privacy.
· Encrypted blocks cannot be simulated with S7-PLCSIM.
Russian wrote:Новый метод защиты функциональных блоков (FB) и функций (FC) в Step7 V5.5.
Программный код шифруется 128 битным ключом в программаторе, в защифрованном виде передаётся в контроллер, где и дешифруется.
Данный метод защиты блоков применим только к новым процессорам s7-300 V3.2 и s7-400 V6.0.
Защищённые данным методом блоки нельзя открыть в предыдущих версиях Степ7.
Защищённые данным методом блоки нельзя симулировать в S7-PLCSIM.
Re: [About]: Step7 v5.5 Block Privacy v1.0
and WinAcRTX...?
In my comp is Ok.ilndep wrote:I install Step7 V5.5 and after new S7-Block Privacy but when I lunch S7-Block Privacy the same program close immediatly. Why ?
The installation of Step 7 V5.5 overwrite Step7 V5.4
Hi CoMod,
to run S7-Block Privacy I must close all files of antivirus by Task Manager Windows.
What is the connection with antivirus ?
With KIS2011 it work.
See blocked program and unblock S7-Block Privacy
The program is not blocked but it is closed in automatic !!!
I don't understand why ?
Send to F-Secure support.
When Kaspersky hurt , I'll switch off
i have testet v5.5,but i cant found the block privacy button,
im serching on my comp for the s7blpapx.exe but not found,
why that...?
why that...?
Install manually from
Step7 V5.5\CD_2\Optional Components\S7 Block Privacy
Т.е. в контроллере на флешке программа лежит уже без ключа?Программный код шифруется 128 битным ключом в программаторе, в защифрованном виде передаётся в контроллер, где и дешифруется.
И что тогда мешает сдернуть ее сименсовским программатором или картридером?
На флешке прога лежит зашифрованная. При считывании контроллер ее расшифровывает. Если сумеете ее сдернуть расшифрованную из памяти, то Вам повезло. ПО для дешифровки встроено в операционку. Если у Вас проц не подходящей версии, то исполнение защищенной программы Вам не светит.
Интересно а как проц ее дешифрует без пароля?
Или пароль тоже бросается на флэш?
Надо разбирать S7BLPAPX.EXE в http://rutracker.org/forum/viewtopic.php?t=2537609
Читайте про RSA-кодированиеppp wrote:Интересно а как проц ее дешифрует без пароля?
У меня блоки помеченные encrypt сливаются с контроллера, т.е. в контроллере они не зашифрованы? А brock privacy устанавливаться не хочет, постоянно требует перезагрузить компьютер.
- Faq & Info
S7BLPAPX.EXE это только оболочка. Используется виндошная CryptoAPI экспортируемая с Advapi32.dll, Crypt32.dll и Cryptsp.dll. Тут довольно сложно "разобрать", т.к. нужно работать на уровне ядра виндовс. Шифруется файл на карте памяти, или нет, точно не известно. Само шифрование в ЦПУ 300 или 400 затруднительно, т.к. требует значительных ресурсов процессора. Возможно только реализация на уровне железа, с аппаратно реализованными алгоритмами, как в чип картах. Все это увеличивает избыточнось, снижая надежность. Для решения возможности обойти защиту, необходим образ скаченный с карты с установленным Block Privacy v1.0, образ той-же программы без защиты, и сама программа. Достаточно программы с пару блоками, не пустыми.
Please help for. S7 program plc block privacy password can you help for the password ,,
https://drive.google.com/file/d/0B1R4cD ... sp=sharing
Please help me to find it.
Thanks and best regards,
pls i have some red blocks with password for CPU s7-319 , any help to unlock it
any help pls send it to me by email -****
Необходима помощь в открытии Block Privacy, наладчик который производил ПНР уволился, и ушел не совсем красиво, проект закрыт а пароль он хочет продать, руководство из принципа не идет на контакт с ним, со словами лучше заплатить другому. А я теперь должен что то сделать с этим, нахожусь меж двух огней! есть какие то варианты???
На данный момент нет способа открыть закодированное по Block Privacy.
Как вариант можно выложить копии экранов Симатик Менеджера с перечнем функций
типа
выложить на файлообменник слитую программу или образ карты ММС... может там на самом деле KnowHow.
На мудака подать в суд... это если он работал штатно или по бумажному договору - неправомочное... вредительство и т.д.
типа
Hello everyone
After the function block has been encrpted, how could I unlock it?
Or is there any way to unlock the red block
thank you
thank you
There is no way at present
Very probably on a fake. Here if after that also the block was opened in the editor. I when investigated protection too was got "protection removals", but the block really did not open
Hello. how can you download this file. the link does not work. Can anyone help me ? thank you very much
are you sure ?
I have tried it and I guarantee that it works properly.
Do not forget that if you have not succeeded, nobody can succeed!
Hello. sorry SHKODRAN but I can't download the file; can you upload the right link or tell me how to download the file? thank you very much
Link is working properly.
Regards.
Spoiler
Regards.
and where is the file "patched_S7BLPAX.EXE" itself?
Right now in the hands of those who patched it.
It will not be public, as it should be.
Maybe I am mistaken, but in video there is no opening in the editor of blocks.
This video = fake
This video = fake
Hi SHKODRAN. Sorry, but you don't see anything in the video and I can't find any download links. I would like to understand if you want to share the info with us all. Give us a clear answer. Thank you.
Hello.
I also associate myself with what was said by dj1178; in my previous post I expressed myself badly. The video is correct and you can see how the procedure works. Unfortunately, you still can't figure out where to find the cracked file. Thanks for the info you want to share. Hello.
The file will not be public.
When it is fully functional in every aspect, I will tell you where to request to unlock.
Hello. have there been any developments on this program? thank you very much.
hi everyone, have there been any developments? thank you very much
Hello.
thank you very much
You have send me file unblock FC FB step 7 "privacy" ?
email: peter.dinhtan@gmail.com
thank you very much
See hope! Start installing OD decompiler software challenge!
74/5000
Hello. are there any developments or updates for this software? thank you very much.
Hi everyone. no development yet? thank you very much.
Hi all.
That is really some nice work there. Congrats on the accomplishment!
Of course that, if this can be released, it would be great.
as yet there have been no communications. it is not clear if the softre is complete and if it can be used. does anyone know something? thank you so much.
Someone to update the topic?
hi, does anyone have any updates on this? thank you
I'm sorry, never can be public.
Regards.
Regards.
