Good day!
Please tell me why the 1756-IF16 module in the online mode has clear channels that give the maximum ADC code and the odd channels have the minimum ADC code? There is nothing connected on the channels. The module is configured as REAL from 0 to 20000.
Signal Processing Algorithms for Open and Short Circuits?
1756-IF16
Re: 1756-IF16
Problem solved. When connecting a common minus to the module, everything works correctly
