[?+]: Weintek XOB file unpassword
raxonyo
Post by raxonyo » Tue May 06, 2014 4:48 pm
i have a problem, i get project from my hmi. Project is in .xob format. I try to decompile this project to .mtp format using EasyBuilder8000 -> Tool -> Decompile, but i dont have password (default password - 111111 is not correct ). Mayby sombody know possibility to restore password from .xob file ?
vlad2006gr
Re: XOB file password
Post by vlad2006gr » Thu May 08, 2014 6:44 am
Send me a project *. Xob format, I decompiled the project and send you.
baduynamduoc
Post by baduynamduoc » Thu Aug 21, 2014 1:22 am
I give file project*.pkg format. You can decomplie the project and send me :
baduynamduoc@gmail.com.
Help me. Thanks.
Link file : http://www.data.webdien.com/free/dow...90be216facc2c8
vlad2006gr
Post by vlad2006gr » Mon Aug 25, 2014 6:11 pm
file project*.pkg format- This file format program eView- EV5000 from Kinco
See http://www.kinco.cn/html/en/NewsCenter/ ... 28473.html
The format differs from Weintek.
vlad2006gr
Post by vlad2006gr » Mon Aug 25, 2014 6:31 pm
baduynamduoc quote:
The file is corrupt and can not be decompiled.
gycu
Weintek HMI xob file password
Post by gycu » Tue May 24, 2016 9:30 am
Hello guys,
I have a Weintek MT8121X. I got a xob file from it but when tried to decompile, it asks for password. I tried the default 111111 but did not work. I searched the related topics but could not find anything useful.
Please help me find the password.
Thank you very much in advance.
PS: If needed, I can upload the file.
Schtiel
Post by Schtiel » Mon May 30, 2016 7:07 pm
gycu
Re: Weintek HMI xob file password
Post by gycu » Tue May 31, 2016 12:22 pm
Thanks for the suggestion, Schtiel, but I read that topic (and others) already. Unfortunately, I don't have the*.mtp file, I only have the compiled version (*.xob) which needs to be decompiled first. In order to do this, it asks for password. I downloaded the file from HMI to a USB stick.
Any help would be much appreciated.
LE: This is how I should decompile if I had the password
http://www.imenista.com/MT8000%20HMI%20FAQ/FAQ_09_How_to_Decompile_the_xob_file_which_uploading_in_the_USB_Disk.pdf
LLE: It could also have the "Decompilation is prohibited" checked though but I'm hoping it wasn't :)
vlad2006gr
Post by vlad2006gr » Tue May 31, 2016 1:51 pm
Poor reading. Again read carefully. Do you have a file *.xob? He needed to get the decompiled file.
Put the file *.xob on a file exchanger.
gycu
Post by gycu » Tue May 31, 2016 5:41 pm
Maybe I missed something or I didn't get it.
I sent you a pm.
Thank you, sir!
vlad2006gr
Post by vlad2006gr » Wed Jun 01, 2016 4:46 am
gycu wrote:Maybe I missed something or I didn't get it.
See PM.
gycu
Post by gycu » Thu Jun 02, 2016 6:13 am
Received it, thank you so much, Vlad, although I have no idea how you did it, you've been a life savior!!! (tyou)
cheers
pmpatel34
Post by pmpatel34 » Mon Jun 13, 2016 5:52 am
i have a same problem, i get project from my hmi. Project is in .xob format. I try to decompile this project to .mtp format using EasyBuilder8000 -> Tool -> Decompile, but i dont have password (default password - 111111 is not correct ). Mayby sombody know possibility to restore password from .xob file ?
help
fractal
Post by fractal » Fri Jun 17, 2016 1:24 pm
I have same problem.I codnt xob password using hex editor program for decompile.
can you help me to decompile ?
or how can crack xob password?
I have usb backup hmi program.
it has xob password.
so I codunt decompile...
this situation what can I do?..
thans a lot..
vlad2006gr
Post by vlad2006gr » Fri Jun 17, 2016 8:36 pm
Download the project (*.xob) to any file sharing, and a link to the forum or pm.
unlockplc
Post by unlockplc » Tue Jun 21, 2016 6:08 pm
You can go here: http://unlockplc.com/crack-plc-hmi/
Or send the XOB file to me: unlockplc123@gmail.com
decathlete
Weintek HMI XOB password
Post by decathlete » Mon Aug 22, 2016 8:37 pm
Hi.
I downloaded the .xob file from HMI. But file is protected and i can't decompile it.
I open the file in HEX editor but don't find nothing.
In older posts links is dead.
Help me please. :wink:
chessbana
Weintek HMI .xob file password
Post by chessbana » Sat Jan 14, 2017 6:52 am
Hello guys,
I have a Weintek MT6070iH. I uploaded a .xob file from it using EB8000 v4.66 with default password 111111 successfully, but when i tried to decompile, the same password did not work.
Can anyone help me find to find the password or convert it to .mtp file for me?
The .xob file can be uploaded from the following link:
https://files.fm/u/pbt6skt9#_
Appreciate all the help i can get, thanks very much.
vlad2006gr
Re: Weintek HMI .xob file password
Post by vlad2006gr » Mon Jan 16, 2017 8:49 am
chessbana wrote:but when i tried to decompile, the same password did not work.
Take away
https://www.sendspace.com/file/caorhk
Good luck!
chessbana
Post by chessbana » Wed Jan 18, 2017 7:01 am
(pgood) (pgood) Thanks alot vlad2006gr!!! Can share your method if you don't mind?
khianon
Post by khianon » Mon Apr 10, 2017 10:53 am
I have same as problem, can,t convert from xob to mtp file.
Can help Me ?
link file:
https://www.dropbox.com/s/y5i2306miuwio ... a.xob?dl=0
Thks
Rgds
Heryanto
vlad2006gr
Post by vlad2006gr » Mon Apr 10, 2017 8:31 pm
Panda Gendut
Post by Panda Gendut » Wed Apr 12, 2017 3:42 am
Dear Vlad,
Can you also help me to convert to *.mtp ?
https://www.dropbox.com/s/3ss8y9q48nmc6 ... 1.xob?dl=0
vlad2006gr
Post by vlad2006gr » Wed Apr 12, 2017 1:32 pm
Panda Gendut wrote:Can you also help me to convert to *.mtp ?
http://dropmefiles.com/8tGME
Good luck!
Panda Gendut
Post by Panda Gendut » Wed Apr 12, 2017 4:10 pm
thank you so much
khianon
Post by khianon » Wed Apr 26, 2017 4:26 am
Dear Sir,
thanks very much
Rgds
Heryanto
khianon
Post by khianon » Tue Jun 06, 2017 2:55 am
Dear Vlad,
Could help me convert file below to weintek mtp file?
https://www.dropbox.com/s/behga8j7klmfz ... a.xob?dl=0
Rgds
Heryanto
vlad2006gr
Post by vlad2006gr » Tue Jun 06, 2017 4:35 am
khianon wrote:Could help me convert file below to weintek mtp file?
https://www.sendspace.com/file/fgohzr
Good luck!
khianon
Post by khianon » Mon Jun 12, 2017 5:33 am
Dear Vlad,
Many thanks.
Rgds
Heryanto
douyi
Post by douyi » Wed Nov 08, 2017 6:15 pm
Dear vlad,
Do you mind convert the xob file to mtp for me as well? Thanks a lot!
Regards,
douyi
https://www.mediafire.com/file/6rra62w5 ... T6100i.xob
vlad2006gr
Post by vlad2006gr » Thu Nov 09, 2017 10:07 am
douyi wrote:Do you mind convert the xob file to mtp for me as well? Thanks a lot!
No file....
ccoa
Post by ccoa » Fri Dec 15, 2017 8:29 am
Could you decompile this file please.
http://www.mediafire.com/file/8f1gazqg19rs1s5/HMI.xob
aoyon7
Post by aoyon7 » Mon Dec 18, 2017 7:20 am
Dear Vlad,
Kindly need your help to decompile the .xob file to mtp? Thanks in advance!
File: https://drive.google.com/file/d/10GHThh ... eK7vB/view
Regards,
Aoyon
toms5758
Post by toms5758 » Wed Apr 11, 2018 12:25 am
Dear Vlad,
Could you please decompile this xob files,
https://drive.google.com/open?id=19vhS3 ... ycmv3uUukv
Regards,
Tony
vlad2006gr
Post by vlad2006gr » Wed Apr 11, 2018 7:21 pm
toms5758 wrote:Could you please decompile this xob files
see PM
INGELM
Post by INGELM » Sat Apr 06, 2019 12:09 pm
I performed a back up to a HMI WEINTEK MT6050i, but now I need to decompile de .xob file, I tried with default password 111111 and doesn't work, can you guys help me to find the password?
Thank you in advance
XOB file: https://drive.google.com/open?id=1jkr8d ... Vim42hQzvQ
vlad2006gr
Post by vlad2006gr » Sun Apr 07, 2019 8:22 am
See PM
arunmp11
Post by arunmp11 » Mon May 13, 2019 11:47 am
Hello guys,
I have a Weintek tk6070iH. I uploaded a .xob file from it using EB8000 v4.65 with default password 111111 successfully, but when i tried to decompile, the same password did not work.
https://drive.google.com/file/d/1VhMzVc ... sp=sharing
ziconltai
Post by ziconltai » Mon May 13, 2019 2:49 pm
Hi arunmp11!
Is that a DONGGUAN C-WIN AUTOMATION EQUIPMENT Co,.LTD?
arunmp11
Post by arunmp11 » Tue May 14, 2019 3:31 am
Dear sir,
You are absolutely correct. Please send me the password or mtp file for that.
thanking you,
Arun
arunmp11
Post by arunmp11 » Sat May 18, 2019 7:26 am
any one can help
arunmp11
Post by arunmp11 » Sun May 19, 2019 10:09 am
actual the file was prohibited for decompiling.
any one can do it
Paul7
Post by Paul7 » Sun May 19, 2019 3:22 pm
Hello
I have a Weintek MT510TV HMI and when trying to upload it, I was requested a password.
I tried the default password "0" (without the ") and the it did not work.
The PLC was also password protected, yet this number was available. I tried this number on the HMI and it did not work.
Is there a way how to find it?
rgds
Paul
vlad2006gr
Post by vlad2006gr » Wed May 22, 2019 5:28 am
arunmp11
Post by arunmp11 » Sat May 25, 2019 8:13 am
please help me
Niconora
Post by Niconora » Sat May 25, 2019 9:48 pm
You can´t recover this project, as you said this have unable to decompile.
by the way, if vlad2006gr can´t help you, then forge it.
arunmp11
Post by arunmp11 » Sun May 26, 2019 10:56 am
you are correct (h)
and the god will help me sure :cry:
ziconltai
Post by ziconltai » Tue May 28, 2019 1:46 pm
Hello
rgds
Paul
See this Video please
https://www.youtube.com/watch?v=HskX9Pitlhw&t=82s
arunmp11
Post by arunmp11 » Thu Jun 20, 2019 6:04 am
all file was cracked :haha:
duong23199922
Post by duong23199922 » Tue Jul 09, 2019 4:04 am
heloo. i have file program used upload from hmi mt6070ih. i want to open it to view screes and edit, but i not open it. plese help me. thank you.
https://drive.google.com/open?id=14r8_A ... DLkjO1HzPG.
